03 Maxima turbo
03 Maxima turbo
Hey all I currently have an 03 max turboed here are her specs
Custom turbo kit
T3/t4 Gt35 turbo
68 mm tial waste gate
Tial blow off valve
Tuned on AEM "fic" plug and play harness "no wires cut"
Upgraded fuel management system
255 walbro fuel pump
Fuel pressure regulator
650cc injectors
NWP 5pc spacer kit
Custom block off plate
Custom ported Intake manifold
3" straight pipe
Apexi world sport muffler
Asco light weight flywheel
6 puck clutch
Suspension - d2 coilovers
I have been pondering the thought of going with twins. My question is if anyone knows if a twin turbo kit for a 03 350z will fit my 03 max se. I figure they would being the have the same engine. Just want to confirm before I drop more cash into her. Lmk thanks much.
Custom turbo kit
T3/t4 Gt35 turbo
Tial blow off valve
650cc injectors
NWP 5pc spacer kit
3" straight pipe
6 puck clutch
Of course it won't fit. Why would it? Same engine but one is transverse mounted while the other is RWD!
The flanges themselves would bolt onto your engine yes, but you would have to modify soooooo much of the 350z kit to fit into/around your engine/bay that it would almost be easier to just start from scratch.
U must have not built ur car,did u buy ur turbo car?or is ur really ur turbo car,u mentioned u tuned on aem fic and u have an upgraded fuel management system,wat do u mean?
