ve3ode turbo shut off when hot (video)
Also check the wiring/connector prongs on the sensor/harness. They like to oxidize and turn green and they give Z32s and 240's all sorts of crazy issues. So presumably they would also be very prone to giving our cars the same sorts of issues.
- fix the vac leak
- your running a bit too lean for cold start (related to vac leak)
- your idle is also low for cold start
so what happens when your engine warms up...the temp sensor tells the ECU to bring the idle down to normal idle (650 or so). if your cold start idle is at 550 and it should be like 1100 to 1200 then what do you think is going to happen when the engine warms up and the ECU tells the engine to idle down and stop cold start enrichment?
you know you have a vac leak...fix that first. don't start chasing other issues until you fix the issue that's right in your face.
Problem solve car holds idle when warm. It was a vacuum leak that was a small one on the iacv gasket. As soon as iacv switches to off when car hets warm up. The leak would increase. I made another custom gasket marker and it held idle this time. I drove it around the block. It ran like **** because its not on 15* degree timing and tps is off tune and idle is low at 600 rpm. After test drive i notice my radiator was leaking. 2 minutes later raditor pop on the bottom corner. Smh
Im glad it runs, so hsppy i did the timing job right. And super lucky to have you guys help. Thanks everyone. Now its time to buy a timing gun and radiator. Adjust tps and i should be ready to schedule a tune with my nistune.
P.s iacv gasket is
P.s iacv gasket is
datechnician915
04-05-2016 06:33 PM
BlackoutSE
03-31-2016 07:00 AM
