05-06 stage 2 stillen supercharger for g35 auto
Thanks for the quick response I am really looking for a cheap supercharger that will fit. Cause it's a automatic and I. Not trying to kill it. I. I. A budget I want to feel that boost.
What supercharger you have on ur setup?
You got the wrong car unless you can A. Do all the work yourself and B. Be able to custom make your own setup. There's next to no aftermarket support for these cars and what parts are available usually aren't cheap. If you're looking to go with a supercharger it's going to be a lot of custom work. No bolt on kit for a 5.5 gen.
As far as finding a cheap blower goes, I guess it depends on your definition of cheap. The blower isn't the problem to find it's making it work on the car. You won't be able to buy a kit that you can install. If you had a 00/01 then yea you might find something. Nothing was ever designed for our model. You would be designing a mount that works on our timing cover and other obstacles. I really think you need to read up on the car. A good place to start is in this section if you're planing on forced induction. In my opinion you'd be better off with a turbo setup. You can do it on a budget but it's still going to cost 3-5gs. That's the very low end. You won't be able to safely do it for under the 3G mark I'd say. That's being patient and waiting for the right deal. Also buying a lot of used parts.
These aren't civics where you can spent 900 and you have everything. Not with these cars. Start by reading the stickies in this section.
i30krab
06-04-2022 01:43 PM
QueensMAX
35
04-12-2016 01:16 PM
mjf3232
03-26-2016 12:05 AM
