08 Sentra SE-R rims on 02 Max???
Old 05-12-2014, 07:23 PM
95VQ30's Avatar
So I picked up a set of newer Sentra SE-R rims and now I am wondering if they will even fit without spacers. I have a worry that they'll rub against the suspension components. I'd try a test fit but it is going to rain all week.
The size of the SE-R rims...
225/45/17
offset is 50mm
so the new rims are 10mm wider with 10 more on the offset but the tire profile is 5 less. I have searched and searched for an answer with no luck.
Will they fit?
Thanks in advance
95VQ30 is offline
Old 05-14-2014, 02:58 AM
95VQ30's Avatar
95VQ30 is offline
Old 05-25-2014, 05:33 AM
asand1's Avatar
Aren't they 4 lug?
asand1 is offline
Old 07-22-2014, 01:08 PM
Sean_a33's Avatar
I'd say so
Attached Thumbnails 08 Sentra SE-R rims on 02 Max???-unnamed-1-.jpg   08 Sentra SE-R rims on 02 Max???-unnamed-4-.jpg   08 Sentra SE-R rims on 02 Max???-unnamed-3-.jpg   08 Sentra SE-R rims on 02 Max???-unnamed-2-.jpg
Sean_a33 is offline
Old 07-31-2014, 07:04 AM
dot dot dot ...
NmexMAX's Avatar
+50 is horrid unless they're 10" wide.
I've got 8.5" + 28 and that's perfect.
NmexMAX is offline
litch
123
01-04-2024 07:01 PM
coolsun
Wheels/Tires
11-13-2016 05:01 PM
Fbana41
08-29-2016 12:18 PM
Luigi623
09-21-2015 01:42 PM
0m3nc0w
09-11-2015 05:21 PM
Quick Reply: 08 Sentra SE-R rims on 02 Max???
