Bent rim, repair or replace?
Old 03-01-2015, 03:48 PM
00 Max's Avatar
After having my wheels balanced one ended up being bent on the inside, so it was put on the right rear. I have a small but noticeable shimmy at highway speeds. Local places can straighten it for around $40 (I think with a hammer). I'm sure when I ask if it will still shake on the highway they will say no. Will it ride smooth with a quality repair or should I just buy another rim? Thanks.
00 Max SE
00 Max is offline
Old 03-10-2015, 12:19 AM
carlem9's Avatar
The shop that balanced your wheels should be able to tell the severity of the bent. If it is really minor, try to fix it first.
carlem9 is offline
Old 03-10-2015, 04:47 AM
00 Max's Avatar
Thanks for the reply, that's exactly what I did and the rim is fried.
00 Max is offline
Old 03-17-2015, 02:38 PM
MaximaDrvr's Avatar
Steelies, alloy, or aftermarket and how bent it is would influence the answer.
$40 isn't much if it fixes your problem, but I would get a guarantee on that work if the wheel isn't round. As I was once told, "you can balance an egg, but doesn't mean it will roll well."
MaximaDrvr is offline
Old 03-17-2015, 03:01 PM
00 Max's Avatar
I found out my egg rolls like frankinstein. Time for a new one.
00 Max is offline
FlaMark
25
08-28-2015 10:15 AM
scarletsosa
08-17-2015 09:09 PM
Samedi
08-12-2015 01:54 AM
Quick Reply: Bent rim, repair or replace?
