Finally, 14's
All the car needed was a CAI and some cooler air :)
The track was hooking okay, my same 2700 rpm launches net me 2.29 shorts, and the high 60 degree air let me grab a mph. 2.29 short, 14.96 & 91.78 The only thing done to the car is place racing CAI and removed spare tire and jack. And too my suprise, my MEVI was waiting for me when I got home:) Doug D |
nice! :)
I think you might get a little better results with a hybrid setup, though. What was the humidity? |
congrads
Re: Finally, 14's
With MEVI can get into the low 14's...:D
Originally posted by DougsfastZ All the car needed was a CAI and some cooler air :) The track was hooking okay, my same 2700 rpm launches net me 2.29 shorts, and the high 60 degree air let me grab a mph. 2.29 short, 14.96 & 91.78 The only thing done to the car is place racing CAI and removed spare tire and jack. And too my suprise, my MEVI was waiting for me when I got home:) Doug D |
Re: Finally, 14's
Good job Originally posted by DougsfastZ All the car needed was a CAI and some cooler air :) The track was hooking okay, my same 2700 rpm launches net me 2.29 shorts, and the high 60 degree air let me grab a mph. 2.29 short, 14.96 & 91.78 The only thing done to the car is place racing CAI and removed spare tire and jack. And too my suprise, my MEVI was waiting for me when I got home:) Doug D |
Good job doug.
Could I trouble you to post your intermediate numbers too? I just want to compare numbers between my best run & yours. I know my shifts aren't fast so that's costing me time. Thx. :)
Originally posted by StygianMax Could I trouble you to post your intermediate numbers too? I just want to compare numbers between my best run & yours. I know my shifts aren't fast so that's costing me time. Thx. :) |
Originally posted by Victim64 What mods did you have when you ran the time in your sig? What mods do you have? |
Originally posted by StygianMax I have my mods listed in my sig. The most significant thing is the exhaust system which is 2.5" dia. throughout from exhaust manifold back to muffler tips. I discovered later one of my front wheels was toed-in beyond the maximum recommended. I waited too long to do my front-wheel alignment after I installed the springs/shocks. Now that my toe-in is back within spec, I should be able to get into the high 14s next Spring. What mods do you have? Times in my sig were when I first got the car. Have intake and y-pipe now, with B&G's and KYB's in the mail. Here are the results from after the y-pipe install: http://forums.maxima.org/showthread.php?threadid=166865 Once I get off the line I am expecting 14.5's -14.6's at 94mph |
how are you guys getting good launches like that?
when i went to the track it felt so slippery compared to a normal road. the best i could do was a 2.36 60ft. i kept burning my tires, from lauching at 750-1500 (tried different things) im not sure if its me or the track or what...but that's pathetic. i went with 4 other maxima's, and the best 60ft i see is a 2.359 when you guys go to the track, is it really really slippery? there was a ton of burned rubber left from these huge domestic muscle cars running with slicks. |
Originally posted by Dev how are you guys getting good launches like that? when i went to the track it felt so slippery compared to a normal road. the best i could do was a 2.36 60ft. i kept burning my tires, from lauching at 750-1500 (tried different things) im not sure if its me or the track or what...but that's pathetic. i went with 4 other maxima's, and the best 60ft i see is a 2.359 when you guys go to the track, is it really really slippery? there was a ton of burned rubber left from these huge domestic muscle cars running with slicks. |
Originally posted by Nealoc187 Were you going through the water by chance? |
nice :thumbsup:
Man, I cant wait until I can get out here sometime next year and go to the track. I am really curious what I can run. Plus by then I will have more mods :D
SuDZ |
Originally posted by Dev well the cars ahead of me were doing burnouts in the water, i tried my best to avoid it by going around. if i avoid the water all together, ill end up in the soil, which will probably mess up my traction even more, but i did go off to the side as far as the pavement would go. |
when you go to the track, right before the line, is there like a bunch of burned rubber sitting there? cause im sure that screws up traction, i burned through first so easily it wasn't funny. even the auto's could burn through first, which isn't possible on the street. on the street i don't burn through first unless i intend to, but at the track it's hard not to.
Originally posted by Nealoc187 Good job doug. |
| All times are GMT -7. The time now is 02:55 PM. |
