List your mods! - Page 3 - Maxima Forums
List your mods!
Old 07-20-2005, 12:38 PM
  #81
I love lamp.
maximase86's Avatar
Keep in mind it's small quanities, and it's atomized usually.
S
maximase86 is offline
Old 07-20-2005, 02:49 PM
  #82
I'm needing a caw
Jeff92se's Avatar
How large is the water/alcohol tank? How long does it last?
Jeff92se is offline
Old 07-20-2005, 05:38 PM
  #83
Since I took all the EGR crap out of my car, this opened up a whole bunch of space on the drivers side of the engine compartment. I mounted a large windshield washer tank as the source of the liquid. How long does it last? Lots of variables on this one: jet size, pump flow rate, trigger point (at what PSI does it kick in), how heavy is your foot. :-)
KALSC is offline
Old 07-21-2005, 11:01 AM
  #84
I'm needing a caw
Jeff92se's Avatar
Well in general terms. 1 day? 1 week? 1 month?
Jeff92se is offline
Old 07-21-2005, 11:20 AM
  #85
2nd Gen Boostinator
Big_E-Dog's Avatar
hey you guys what is the screw on the base of the distrubitor called and what is it for?
Big_E-Dog is offline
Old 07-21-2005, 11:28 AM
  #86
HR Swap Pioneer
timming?? idk i need to check my timming
SurraTT is offline
Old 07-21-2005, 11:53 AM
  #87
1 day, 1/2 week, one week, it all depends. I always check the tank and just top if off, right now I am using just water. Easy as pie.
KALSC is offline
Old 07-21-2005, 12:04 PM
  #88
Blown
thats the screw that you use to set your timing. Shine a timing light in there then loosen the screw and the the dis, clockwise or counter-clockwise to get your timing set where you want it then tighten the screw back down. Don't tighten it down too much though, I snaped the head off of my screw and it was a pain to get out.
cardana24 is offline
Old 07-21-2005, 01:32 PM
  #89
I love lamp.
maximase86's Avatar
I thought it was for the warp tranducer myself.....
S
Old 07-21-2005, 02:48 PM
  #90
HR Swap Pioneer
btw speaking of timming, i need to set myne, ( i played with it and i think its not helping on gas) so i wont to get it set right, mabey not factory but right, i do have that da** tic tic at idle
i might buy a timming light today depending on $$$$$$$$$$$
SurraTT is offline
Old 08-01-2005, 09:15 PM
  #91
Man my auto is going to hell so i can't use the overdrive. Going 85 90 on the way to work has my mileage down to 16-18mpg.
UberZogster is offline
Old 08-02-2005, 07:16 AM
  #92
The timing isn't going to stop it from going 'tick,tick'. It's probably the hydraulic lifters ticking. What's your oil pressure at idle? And what weight oil is in there?
wylie-c is offline
Old 08-09-2005, 06:46 AM
  #93
mine is a 92(same shape as your 88) XRT Turbo hardtop and its all stock bar an intercooler
to the max is offline
Old 08-09-2005, 07:29 AM
  #94
HR Swap Pioneer
10w30 at idel its ummmm (i changed the gauges out i had the 90 120 psi ones,i guess its like 20 idk
would 10w40 help??? i use castrol gtx high mileage, with K&N oil filter
SurraTT is offline
Old 08-09-2005, 08:45 AM
  #95
Blown
post some pics if you have them
Old 08-11-2005, 04:39 AM
  #96
i dont know how to post pics on here but if someone wants to do it for me i could email them to you!
Old 12-11-2016, 11:46 PM
  #97
Acronym ?
[QUOTE=maximase86;2892359]Most people know my mods, but I'll list them again.
maximase86
86 SE, 5-speed
Intake - Full CAI
Exhaust - 2.5" Cat-Back, Stillen Exhaust with single 4" tip
Engine - Unorthodox Racing UDP, 300zx ECU, Lots of Wireloom
Tranny - 3rd Gen 5-speed
Suspension - 3rd gen FSTB, 3rd gen Eibach with 1.2" drop, KYB GR2's, Addco RSB
Exterior - Dark Red Metallic, color-keyed mirrors, grill, lights, bumpers, and airdam. 5-lug conversion, 18" TSW Trophies with 215/35/18 Yokohama Parada/Parada Spec II rubber, 15" 97 I30 Rims with 205/55/15 BFGoodrich Traction T/A rubber, PIAA Lighting throughout, clear front turnsignals with amber bulbs, amber cornering lights
Interior - Clear courtesy lights with superwhite bulbs, brush aluminum dashkit, Reverse indiglo gauges (since removed since they stop working)
Audio - Kenwood Excelon HU, Components, and subs, PPI Amps.
Coming soon: Running engine (VG30ET?), KALSC Turbo Kit, Crossdrilled/Slotted Rotors maybe.
Can you explain to me the acronyms ? Sorry I'm new to this
I'm looking into the suspension swap from 3rd gen.. what do you have.
Chrismkellyjr is offline
Old 06-28-2017, 12:21 PM
  #98
[QUOTE=Chrismkellyjr;9134060]
maximase86
86 SE, 5-speed
Intake - Full CAI
first no point in doing a 3rd gen suspension swap unless you want to go 5 lug, it's the same type of parts other then the hubs, read though the suspension sticky for more info..... the acronyms like CAI= Cold Air Intake, UDP= Under Drive Pulley FSTB= Front Strut Tower Brace
vernk is offline
Old 06-28-2017, 12:28 PM
  #99
but now that you brought this back up
short ram intake
coil overs all 4 corners
currently rolling on G20 rims
500lb/in springs all the way around
updated sound system with single 12 sub
more will be done once I get my S12 up and running
vernk is offline
Old 10-16-2017, 12:52 PM
  #100
well I guess I should add, running a megasquirt MS3/MS3X now
vernk is offline
Old 01-22-2018, 07:21 AM
  #101
I know this is an old thread, but like a classic car I like to keep 'em alive.
1987 Maxima Mighty Max (what a lame name for such an awesome car).
All stock and mostly going to stay this way. I say mostly because once I locate all the interior parts that I need I have the following audio system ready to install:
Sony RSX-GS9 Hi-Res Digital Media Receiver w/ Bluetooth
MTX Audio 15" T9500 Series T9515-44 Subwoofers
4000W.
Two Cerwin Vega SPRO1400.4
1400W Stroker Pro Series Amplifiers.
Rockford Fosgate Punch Pro PPS4-10 700W 10" Midrange Speakers.
Rockford Fosgate Power T1T-S
1" 150W Power T1 Series Dome Tweeters.
deadzoo is offline
MaxLvr21
10-17-2015 01:11 PM
REDinLV
09-28-2015 01:31 AM
09-27-2015 09:37 AM
Quick Reply: List your mods!
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
