For when your ECCS dies
11 Attachment(s)
Well mine went out so I ordered one off ebay and this is what came
Attachment 59548 Attachment 59549 boxed that back up and sent it back right away then I ordered what was a factory reman that one didn't work they sent me another one and that one was bad also Attachment 59550 so I ordered a expensive sticker Attachment 59551 should be enough room for the wiring and fuses and every thing else that need to go in Attachment 59552 added a knock sensor Attachment 59553 wide band Attachment 59554 think I have everything worked out for the most part Attachment 59555 Started on the wiring, got all the grounds in and the pull up resistors for the CPS done Attachment 59556 Attachment 59557 Attachment 59558 have most of the wiring figured out and have been taking out wires that are not needed like the old O2 sensor and the diagnostic plug on the front of the intake. Will be working on it after work during the week and hope to be able to get her going this weekend. |
wow that's a lot of corrosion on the circuit board, look like the capacitor have leaked out. That would be expected for a car of that age.
Originally Posted by FanaticMadMax
(Post 9156023)
it came out of NY so think someone pulled it out of a flood car or from the junkyard with a car that the window had been open, but yea it had been wet for a long time.... |
Three bad ECMs and a standalone engine management sticker. Not a bad way to spend $10,000.
Originally Posted by Hectic
(Post 9156342)
shes alive
well a little update before I do the full write up, found where she likes her spark, took a little playing but once I found it everything smoothed out, just a couple more days and I should be able to stop auto tune to and from work, then I will be turning on the fuel cut and EGR to get my MPG back up, still have to install relay for idle up and get idle dialed in a bit better but over all running decent.
Hey cool stuff man. I have MS3 Pro on my '74 Z project car. How do you like the DiY software or have you tried any other type of Aftermarket ecu?
Originally Posted by 83maxattack
(Post 9157737)
Might be a good idea, I've noticed the auto tune does well to get you on the road, but you'll need to actually get in there yourself if you wanna pass emissions i bet. What engine did you get for the 200sx? And is it the 80's rwd or the 90's fwd version? All your pictures are missing.
(Post 9157882)
yea need to get on getting pixs back up, well a link to a gallery, it's a 86 S12 with a VQ getting put in. |
time for a little update, still up and running, getting the tune down been kind of slow going since I data log on the way to work and then on the way home make small changes, had a small coolant leak on the lower intake from the front, O ring got pinched and would leak right after start up then stop once started to warm up. It wasn't leaking right after I got it back together and running, started a couple weeks after I had it back on the road. Had the time to fix it this last weekend and found that the fel pro intake gaskets were not doing that good of job (couldn't find the nice factory ones) so when I put it back together this time used some sealant.... So now I'm running about 10 deg cooler and a bit smoother although I do have to go back though my tune and lower my warm up enrichment temp and a couple other temp based settings, then finish getting my VE table adjusted.
Sounds like alot of work...Do you have a way of saving your settings just in case you screw up again? mI would love to tune something like that but a specific base tune is what you need more than anything else...I take my hat off for to you for all the soldering and crimping you had to do....Your wires seem to be really thick or is that the camera playing tricks with he images?
© 2024 MH Sub I, LLC dba Internet Brands
