88 nissan maxima throttle valve switch curcuit
Where is it and do I have to replace it or can it be fixed it cleaned out?
Originally Posted by Ryan perez
(Post 9194476)
Common Problems If your car lurches a little while coasting in gear towards a red light, it may be that the TPS is not quite right and the computer is switching from idle to running. This can make your car lurch a little because the fuel is shut off when you are coasting in gear to save gas. The switch is opening and closing, turning the fuel on and off. To replace the switch, simply remove the two screws, unplug it, and replace it with the new one. To Test the TPS you will need to disconnect the 3 pin connector on the TPS and test the Top and middle pin for Continuity when the throttle is closed. The continuity should break once the throttle opens slightly.If the contact does not break until higher throttle movement then you can adjust the TPS by loosing the mounting screws slightly and turning the sensor until the contacts break when the throttle opens slightly.To Test the TPS you will need to disconnect the 3 pin connector on the TPS and test the Top and middle pin for Continuity when the throttle is closed. The continuity should break once the throttle opens slightly.If the contact does not break until higher throttle movement then you can adjust the TPS by loosing the mounting screws slightly and turning the sensor until the contacts break when the throttle opens slightly. https://cimg2.ibsrv.net/gimg/maxima....3de3e16c1b.jpg |
© 2024 MH Sub I, LLC dba Internet Brands
