Desperate for wheel hub assembly
So.. my bearing went on driver front.. Damaged the hub. Cant find anything new. Guys im a student on a limited budget and this car is getting me to class.. Can anyone help at all? I dont care if bearing is bad i have a new bearing but a fully working good conditioned 1988 Maxima SE wheel bearing assembly would be a godsend |
like this hub? or do you mean the spindle? you can get the hub on Ebay
https://www.ebay.com/itm/FRONT-WHEEL...frcectupt=true |
it doesn't have to come from a Maxima if you look at the bottom of the page you will see the list of cars that you can get one from out of the junk yard, I might have one laying around in the junk which I can check this weekend if you haven't found one yet. https://www.nissanpartsdeal.com/part...202-50j10.html
Upgrade to 3rd gen hubs
in case you didn't read that he said he's a student on a budget, if he did upgrade to 3rd gen hub then he would have to buy a set of new rim to take a 5 stud since 2nd gen have four stud so not economically feasible for him. So with that being said the hub is relatively inexpensive to get you can get from part store or online.
Not overly expensive if you do it according to your budget...Meaning either buy the front spindles, then rear spindles separately through eBay, Rockauto, partgeek, etc and go to the salvage yard in which you can purchase wheels with tires for $20 each. It can be done inexpensively on a student budget. Think of spreading your spending out in increments like layaway...You can't have everything you mofo's want without some sacrifice!
© 2024 MH Sub I, LLC dba Internet Brands
