Help!!..immediate electric problem I need help with!!!
Ok I go to get going in my car and my corners and my dash lights only come on when I hit my brakes. what's that all about??...Also I have apc superwhites in the corners and I'm only using a 10 amp fuse which for about 3 weeks worked up until this problem..I changed the amp to another 10 and it's still doing the same thing. I don't wanna use a higher amp or anything becuz they said it's not good, i'd jus rather use a bunch of 10's. What do you guys thinks is going on?????
have you done the corner light rewire?
Originally posted by KLoWnPR109 have you done the corner light rewire? |
I had this happen to me, but I just put in a 15 amp fuse and it fixed it. Go over your connections and make sure they are fully covered so that no shorts can occur. A higher fuse was only a temp. fix until I got the shorts fixed. I dunno about the bulb wattage, I have just got stock wattage white bulbs in there right now.
Originally posted by KLoWnPR109 I had this happen to me, but I just put in a 15 amp fuse and it fixed it. Go over your connections and make sure they are fully covered so that no shorts can occur. A higher fuse was only a temp. fix until I got the shorts fixed. I dunno about the bulb wattage, I have just got stock wattage white bulbs in there right now. |
no, i've got some superwhites or hyperwhites or whatever in the 1157, 194, and 9004. But they are all the stock wattage. Most white bulbs that people buy are over the stock wattage.
Originally posted by KLoWnPR109 no, i've got some superwhites or hyperwhites or whatever in the 1157, 194, and 9004. But they are all the stock wattage. Most white bulbs that people buy are over the stock wattage. |
yeah, my 194s turned a color that kinda looks like puke, so i changed them out,and now these have faded into a orangish color.
© 2024 MH Sub I, LLC dba Internet Brands
