door lock actuators
door lock actuators
the actuator in the drivers door on my car doesn't work, but i only realised this after i had an alarm installed, as the remote central locking only opens the other 3 doors, which is very annoying! My question is, will one of the other actuators fit in the drivers door? eg: one of the back doors, cause i can't afford a replacement part right now, and don't really care if a back door doesn't unlock.
any ideas would be greatly appreciated.
Re: door lock actuators
1. Please get a New Holland Tractor and fit a Pearson 32-39 front end loader to it.
2. Now get a 1.8m bucket and fit this to the front end loader. This is easy to do.
3. Now find a soft peice of ground and dig a hole - a very deep one.
4. Now flick the handle on the front end loader and drop the bucket.
5. Fit the Grab to the front end loader and crowd the grab till the handle clicks back into place. Remember to connect the hydralic hoses.
6. Position the prongs under the car and close the grab all the way down. Now lift the car above the hole and drop it in.
7. Back fill the hole.
8. Buy a 4th Gen Cefiro. Dont buy a NZ spec as they are only 190hp and suck in high rpm. Try to get a 3.0 220hp or failing that get the 2.5 190hp which will beat a 3rd gen by a mile anyway.
This will fix the door lock acutor problem.
NZ Max
Re: Re: door lock actuators
Originally posted by NZ Max1
Here is how to fix the door lock acutors.
NZ Max
NZ Max
I don't think he asked what you think of his car, or whether he should buy a 4th gen or not. He was asking a question about a common problem on our cars.
A few things:
The actuators are NOT interchangeable between doors.
Replacement actuators are $100 - 125 - new and used.
Getting them installed can run you another 100 or so.
Good Luck
-Clayton
Re: Re: Re: door lock actuators
Nevertheless, it's hilarious!
I was going to tell you to search on this topic, but after searching myself I found there really isn't that much information on this topic.
A few things:
Good Luck
-Clayton
A few things:
Good Luck
-Clayton
Re: Re: Re: Re: door lock actuators
Originally posted by Maximan190
cant they be resoldered?
you're getting mixed up with door lock timer
door lock timer can be resoldered, usually causes the door locks to stop working more and more often until the power locks dont work at all, you can usually still hear the clicking under the dash but nothing happens
all that starbucks is going to your head
Re: Re: Re: Re: Re: door lock actuators
Originally posted by Matt93SE
I believe I've still got that door actuator in my parts car. shoot me an email if you want a good price on one. (blehm@utulsa.edu)
btw - haven't had time to pull that clock out yet.
-Clayton
magiconthetire
10-26-2015 09:03 PM
REDinLV
10-18-2015 05:31 AM
HerpDerp1919
09-29-2015 02:02 PM
Andy29
09-29-2015 05:32 AM
