Maxima Forums
Maxima Forums (https://maxima.org/forums/)
-   3rd Generation Maxima (1989-1994) (https://maxima.org/forums/3rd-generation-maxima-1989-1994-8/)
-   -   What's Wrong With My 92 GXE?! (https://maxima.org/forums/3rd-generation-maxima-1989-1994/139549-whats-wrong-my-92-gxe.html)
Starchild2k3 Feb 19, 2003 02:43 PM
Wassup you guys im back, I just have one question that is really bugging me. My rpm meter keeps jumping up and down from 2 to 1 to a little lower than 1. My engine is running rough and keeps shaking vibrating when the rpm jumps up and down. Someone told me it's the timing so I turned the distributor cap and it got a little better but still does it, someone else told me it sounds like a hole in 1 of the vacuum hoses, someone else told me it's the btc valve, someone else told me it's the fuel injectors. I just need some help, did anyone else have this trouble before. The car runs fine one second then it runs a little higher, than it goes lower like it is about to shut off, then it jumps back up. I just need some help with my problem, I am hoping it is simple and not hard to fix. Im up for all suggestions. Thanks
P.S.
I did a full tune up, changed all the spark plugs, spark plug wires, distributor cap, rotor,fuel filter,oil filter, changed the oil, and nothing changed. Also changed the whole exhaust system from the y-pipe all the way back thinking something was clogged.
Soul Fly Feb 19, 2003 03:45 PM
i think it MIGHT be your injectot harnesses for your plugs (spark)
Starchild2k3 Feb 19, 2003 05:17 PM
Thanks for the suggestion.Anymore Suggestions though?
CanadianMaxima Feb 19, 2003 09:03 PM
your maf sensor might be dirty. go to radio shack and buy some electric contact cleaner and spray it on the sensor. be careful with the sensor though. its a 4-500$ part if not more
Torres Feb 20, 2003 12:32 AM
Re: What's Wrong With My 92 GXE?!
i had the same problem...and 1 of my injectors gone bad...so check the injectors and find out which is dead.......and 1 thing....don't go 2 the dealership and ask 4 the injectors.......well maybe there in the states thier cheaper..but here in Canada......it's $1000.oo 4 all six ......:mad:
so good luck and fix ur Max up
l8er
Torres
