Maxima 91 audio active speakers system (New head unit installation)
Hi,
I just bought a nissan maxima 1991. My first reaction was to install a new audio head unit with a cd player.
I did install it using an adapter patch, etc...
Everything is working except the rear speakers. If I understand correctly, the rear speakers are Active ones, with an amplifier feeding them ? Is that why I'm not hearing anything ?
If so, is the best idea to just bypass the amplifier and patch the correct wires on the speakers ?
Thanks,
David
Thanks,
David
Re: Maxima 91 audio active speakers system (New head unit installation)
When I replaced the headunit on mine, the rear speakers were louder than the fronts as they were amplified. I bypassed the amp using jumper wires on the connector that plugs into the amp. Now when the fader is set at "0", I get equal sound distribution front and rear.
If you're not hearing anything at all, check to see that the harness is plugged into the amp (it's near the left rear speaker). To bypass, I just referred to a Chilton Manual wiring schematic.
Originally posted by Panzer
Hi,
Thanks,
David
Hi,
Thanks,
David
Originally posted by jakew8
Do you have the Bose system or not? If you do, I'd get an interface so your new headunit will use the amps. They're too good to pass up in my opinion.
But what about the color codes for the wires ?
How I figure out which one are coming from the HU to the amp and from the amp to the rear speakers ?
Everything is on the same wire strap with the connector to the amp (in and out)
are the rear speakers still connected to the amp? if so that don't worry about back there, as long as it plugged in it should work fine. did you connect the speakers correctly up front with the HU and stock harness?
Ok. Lets get things straight.
I cannot use the amp because the rear speakers signal coming from my HU is already amplified. Also, I did not provide power to the amp because my new pioneer radio does not have the power cable to it.
So, my idea was to just bypass the amp and link directly the rear speakers cables coming from my HU on the amp plug directly to the cables going to the speakers. But I need color codes of something to help me decipher which cables are the right one on the amp cable strap (which like I said is In and Out (8 cables for the speakers + power for the amp) of theses 8 cables, 4 are coming from the HU, 4 are going to the speakers. I need to know which ones) ?
Everything is plugged the right way on my HU in the front, I used an adapter patch especially designed for the Maxima.
Panzer
Panzer
but anyways try installdr.com for the wire codes, should be same as the HU up front
Mine did the same. This is how I fixed it:
After I installed my Pioneer HU, they did not work, and the rear Clarion amp has to be bypassed.
Matt93SE has a write up on his page.
Amp Bypass
Follow these directions, and you will be fine.
Thank Matt93SE for the instructions!
Dave
Amp Bypass
Dave
Originally posted by DA-MAX
I think the factory amp is powered by the antenna so as long as you antenna goes up the amp will come on regardless.
Originally posted by Gjohnson
How would that work when playing cd's???
I put a switch inline with the antenna lead, though. It's just a plain radioshack switch and it lives in my ashtray. (no drilling or anything, just comes over the back. and no i don't use the ashtray for trash anymore.)
That way, when playing CD's I can keep the antenna down then raise it when I need it. (Local, high-powered stations won't require your antenna if you've got a good tuner in your headunit anyway.) Plus I can use the switch to raise and lower it real fast, which I have to do to get it to go all the way down sometimes.
Slamrod
08-10-2015 12:33 PM
MikesChevelle
08-06-2015 11:36 AM
