Won't Start
Okay,
I know there are a few things check, but I wondering what is the most common failure Battery is fine Starter fuse is fine Terminals are Clean Won't jump start Will Push start Could it be the clutch pedal start switch? It there a way to bypass it to see, or (even better) is it a cheap part, I can't just go to the dealer and change out. It could be the starter I guess, but when it does kick in, it always seems to be strong Any ideas are appreciated. Thanks |
Is the engine turning over? If so, you can rule out the clutch switch. Need more info.
please help
i have an 89SE and a 93GXE, the 89SE is a 5 spd, it's not starting recently, i cleaned the terminals, jiggle the contact and it start right up, but after switching on and off 3 times, it died again. I replaced a battery but it wouldn't start, the engine wouldn't turn, can someone tell me why?
my other question is, my 93GXE's powerlock doesn't work any more, what's the deal? I tried the search function but it's not working can someone please help? |
| All times are GMT -7. The time now is 01:45 AM. |
