92 SE Power Lock, Power Trunk Release Problems
Old 08-19-2003, 01:00 PM
Ninty-two-se's Avatar
A few days after I got my 92 Maxima SE I started having problems with the power locks and the trunk release. Every time I shut my door the doors would lock and my trunk would pop open. Has any one else had this problem? I figure theres a short or crossed wire in the door panel but last time I had the panel off I couldn't find anything. It also will lock randomly (like when it sits over night in my driveway) and the alarm will go off when I try to get in it after it unlocks. Could it have to do with the lock timer at all?
Also, are the doors susposed to lock when the door is slammed, like a safty feature, or is that another electrical gremlin that I need to sort out...
Ninty-two-se is offline
Old 08-21-2003, 07:43 PM
travr6's Avatar
It sounds like your door lock timer located on the right side of your steering wheel under the dash. Check the FAQ's
travr6 is offline
Old 08-21-2003, 07:47 PM
STFU n00b!
Matt93SE's Avatar
it's not the door lock timer. sounds more like you have a short (or several) somewhere else. check the wiring harness going through the door and into the car. the door hinge area sounds to be the culprit.
Matt93SE is offline
MAXSE5SPD
09-17-2022 04:00 AM
King_Ten_Ahead
09-30-2015 04:27 PM
intimidator
09-05-2015 07:23 PM
coasterswim
09-02-2015 07:43 AM
Hailstatejig
09-02-2015 06:52 AM
Quick Reply: 92 SE Power Lock, Power Trunk Release Problems
