Maxima Forums
Maxima Forums (https://maxima.org/forums/)
-   3rd Generation Maxima (1989-1994) (https://maxima.org/forums/3rd-generation-maxima-1989-1994-8/)
-   -   will 19's fit? (https://maxima.org/forums/3rd-generation-maxima-1989-1994/185779-will-19s-fit.html)
BlueandWhiteMax Oct 10, 2003 06:16 AM
will 19's fit?
Hey guys I'm wondering if I got 19's will they fit? Without rubbing that is? I would run the rims on 215/35 tires but my car is lowered already 2" by the Sprint Springs. it sa 94 maxima.
NT2SHBBY Oct 10, 2003 06:32 AM
wow I haven't had a 3rd gen in years but I already know 215's are thin a$$ tires....might wanna go 235
Matt93SE Oct 10, 2003 07:17 AM
anything will fit if you get the width and offset right. do some searching in this forum, you'll find a ton of useful information.
Maxima-4DSC Oct 10, 2003 07:41 AM
with a 2 inch drop already then adding the 19's they will rub unless like matt said you get the settings just right.
GdOutMaxima Oct 11, 2003 07:47 PM
Alright, well the 215's were the only way to go. For some reason when I had 235's they rubbed with my 17s when I turned the wheels. But anyways I am just going to get some 18's instead. Thanks for the help though.
Logan91VE Oct 11, 2003 11:21 PM
good choice, 18's and 17's are the right sizes for a third gen(visually), get at least 225 tires.
espimax Oct 13, 2003 01:06 PM
i got 19`s on my 93 se
i have 19x8 on 235/35/19 i just needed some small spacers for the back put them on and no problems. they are 42 offset.
Jack. Oct 13, 2003 01:10 PM
Yeh a guy who had just bought 20's had a pretty large problem that he didn't think fixing was worth the bling bling dubs. So he sold them. If they are worth it, getting it set up right may not be that big of a deal to you.
matt90max Oct 13, 2003 09:07 PM
http://www.rmbuckbuilders.com/bmode/lotus.JPG
i tired 20 inch rims, but they where rwd offset at 15mm and 255/35/20 series tires, they did not fit, but i hammered in the inter finder to get them to turn all the way, they would still rub on the outer finder, i would say 20s would even fit if you have fwd offset and rims that where 7.5 inches, mine where 8.5 mine were drivable, but in turns it would hit the outer finder. im going to try to find 19s with a fwd offset and 225 series tires. i loved how they looked and they do fit on a 4th generation maxima even with a rwd offset
