Maxima Forums
Maxima Forums (https://maxima.org/forums/)
-   3rd Generation Maxima (1989-1994) (https://maxima.org/forums/3rd-generation-maxima-1989-1994-8/)
-   -   Had timing advanced and now car idle's rough (https://maxima.org/forums/3rd-generation-maxima-1989-1994/199848-had-timing-advanced-now-car-idles-rough.html)
94M@X Dec 30, 2003 08:57 AM
Had my 94 GXE timing advanced to 18 degrees and now the car idle's rough. I made sure to switch to 93 octain gas (used 94 on last fill up) but it is still idleing rough. The car also idle's allot lower now. Used to idle at 1k but now it is just over .5k
Should I just put it back to 15 degrees or is this normal?
internetautomar Dec 30, 2003 08:58 AM
put it back and see if it returns to "normal"
94M@X Dec 30, 2003 09:03 AM
good point, will do!
Just curious, has anyone else had similar results with advancing the timing?
bvtran Dec 30, 2003 03:38 PM
It's possible that you didn't do it right if you got one of those advanced timing light gun with a variable setting knob.
Make sure that the knob was set to 18 if that's what you really wanted and make sure it doesn't move while you're setting your timing. Otherwise, if that thing moves, you will not get accurate reading.
AscendantMax Dec 30, 2003 04:00 PM
your old idle is a bit high... should around 750 rpm after the engine is warmed up.
davebond007 Dec 30, 2003 06:13 PM
+1 to fosgate fan.
Plus it might be time for a tuneup for your car.
MrGone Dec 30, 2003 06:59 PM
mine was idling at 200 today :)
bvtran Dec 30, 2003 08:22 PM
It should be 700 w/+- 50 according to the FSM.
MrGone Dec 30, 2003 08:38 PM
yeah, my car isnt to happy right now :(
shoult Dec 30, 2003 11:29 PM
Doctor! Doctor! It hurts when I do dis!
Don't do dat.
Put it back.
internetautomar Dec 31, 2003 08:40 AM
With you as a driver I'm not surprised
94M@X Dec 31, 2003 10:36 AM
Thought advancing the timing was ok as long as you went with higher octain gas?
Aaron92SE Dec 31, 2003 03:43 PM
According to the 1992 Maxima FSM, idle should 750 +/- 50. :D
