Parts car or fix it or sell it? Any help/ideas? (previous message didn't post)
Old Feb 4, 2004 | 04:00 PM
dmitriy's Avatar
92 SE engine problems... Any help/ideas?
Hey Guys...
Well, as sad as it is, but my 92'Maxima SE seems to be having engine problems and I don't have money to put into it. As I posted before, the problem is pretty loud engine knocking (valves) when the car warms up. It just started happening a little over a week ago, and the car hasn't been driven in this condition. The oil pressure seems to be dropping once the oil warms up (oil light comes up and pressure drops to 7-10 psi at idle. For some unknown reason, the engine runs absolutely great (not a single tick) and has great oil pressure right after the oil change (I tried it 2 times). I would change the oil (new filter), car drives like new for 2 days, then it starts knocking again. I ended up changing oil and doing engine flush twice in the last week.
I had a few ideas about it originally:
1) clogged oil pump pick up screen
2) bad oil pump
The first one is about $150 repair or DIY the other one is probably around $500. Mechanic looked at it and said he has no idea what it is until he tears down the motor, which will cost quite a bit... but he said that more than likely it's one of the things mentioned above.
The car has 160K miles on it... and the worst part is that engine was replaced 1.5 years ago and it had only 82K miles when we got it (so right now about 98K miles on the engine).
The body is absolutely perfect - it's a southern car, so there isn't a single rust spot on the body. Shiny paint throughout. No dents/scratches. Interior has leather that was repaired (it had tears on it) and looks pretty good.
Everything else works. Transmission shifts great - no slipping, very smooth shifting. Heater works too. Sunroof/power windows/locks... that's about it.
Also, I ended up spending a small fortune on normal maintanence stuff in October/November of 2003. The car has new tires, brand new battery, new fuel pump, new front suspension, new left lower control arm, new left drive shaft, tie rods and recently changed rear brakes (including calipers).
What are my options at this point? I really do not have even $200 to put into it and was actually planning to sell the car anyway, since I do not need the car (live on campus).
Should I part it? Sell it for parts (as-is)? Put it on Ebay? How much should I expect to get for it? Would getting $1200 for it be realistic?
Anyone here would be interested in picking it up and putting it back on the road? If you have time and space to work on it - it will be a great car and will probably make it to 200K miles easily.
By the way, I am in Michigan (Ann Arbor).
Thanks for any advice,
Dmitriy
Old Feb 4, 2004 | 04:33 PM
harrymay's Avatar
dude, just wait, i couldnt aford at first to get my car running perfect, then i waited til i had the money. $200 isnt bad considering that the car is worth 3000 in running condition.
dont part it out, just wait til you have the money, im sure you can do it all for cheeper than that, like a junked oil pump...
Old Feb 4, 2004 | 06:06 PM
internetautomar's Avatar
mod or sell?
$1200 IMHO is to high,
Price out a JDM motor with the install labor.
and start saving.
As you said you don't need a car right now, so you can let it sit while you accumulate the neccessary funds to fix it.
Old Feb 5, 2004 | 06:13 AM
dmitriy's Avatar
Well... if it's just sitting there, I have to pay for insurance and registration.. still money. Also, JDM motor will probably be worth about 3-4 times more than the car itself.
Also, oil pump itself is not expensive - it's the labor to install it (about 8 hours).
Old Feb 5, 2004 | 06:18 AM
dmitriy's Avatar
internetautomar, what's a realistic price I should ask for the car? I don't really follow the prices on these cars... but I saw them selling around $2000 or a little more in good condition...
Old Feb 5, 2004 | 07:31 AM
mod or sell?
registration you do have to keep up,
But depending on where you live you can not put insurance on it because it is not being driven.
a JDM should only be about $500
To give you an idea on car values.
mx with bad trans couldn't sell for $500
I paid $200 for my 3 cylinder max.
So personally I'd keep it , screw the insurance and put my insurance money into the motor.
This may or may not be legal where you live and I assume no responsibility for following the above recommendations
Old Feb 5, 2004 | 11:56 AM
todamax's Avatar
A motor, JDM or not is about $1000. This is a VE, those aint cheap like the VG.
Old Feb 5, 2004 | 02:09 PM
mod or sell?
All depends on who you talk too
Old Feb 5, 2004 | 08:41 PM
todamax's Avatar
You telling me that you can get a JDM VE for $500? ****, that would be worth it for the VTC's alone.
Old Feb 6, 2004 | 06:30 AM
mod or sell?
After a few phone calls and some strings being pulled.
Old Feb 6, 2004 | 08:40 AM
dmitriy's Avatar
Well.... if you can get JDM VE for $500 with relatively low miles (under 80K) and in working condition... I might actually consider it. Can you tell me whose strings need to be pulled?
Old Feb 6, 2004 | 09:22 AM
mod or sell?
where you at?
Old Feb 6, 2004 | 09:54 AM
xveganxcowboyx's Avatar
I assume it's auto ("shifts smoothly") If I'm wrong i might be interested. Maybe even be interested in auto...... Does it drive reliably or is it totally handicapped? I don't know if you're actually selling. There are lots of recomendations to keep it, but if you want to sell I may be interested.
Old Feb 6, 2004 | 11:42 AM
dmitriy's Avatar
internetautomar,
I am in Ann Arbor, Michigan.
xveganxcowboyx,
The car is an auto. I think I am selling it if you are interested. Everything in the car is reliable... it drives, but with the noise it's making it's probably not a good idea to drive it.
Old Feb 6, 2004 | 11:46 AM
dmontzsta's Avatar
Ford Only.
ummm...VTC's are nothing to be worried about, let them tap I do and my motor has 280,000 miles...you do not need to fear man.
Old Feb 6, 2004 | 12:00 PM
dmitriy's Avatar
That's not VTC's
Old Feb 6, 2004 | 12:50 PM
mod or sell?
shipping in the motor is gonna be the cost prohibitive part of it.
I just got quoted $895 from the first place I called and they don't know me.
So I have no doubt in my mind that I'd be able to find one for about 500
Old Feb 6, 2004 | 01:26 PM
dmitriy's Avatar
What's involved in the JDM swap? Is it a straight drop in?
Shipping on the motor is only around $90-100... I've already had one motor shipped to me from SC to MI for that much... it came on a crate in a truck.... I guess it's a pretty common thing to do.
Old Feb 6, 2004 | 01:28 PM
dmitriy's Avatar
What's the difference, anyway, between JDM and US motor? Where do you even find JDM stuff? I thought it's normally way too expensive to even think about for older cars.
Old Feb 10, 2004 | 06:38 PM
mod or sell?
A JDM motor in our cars is the same thing just usually with lower mileage than is easily found in yards here
Old Feb 11, 2004 | 09:33 AM
dscut's Avatar
[QUOTE=dmitriy]Hey Guys...
Too bad, I am living too far away from Michigan. Otherwise, I would pick up your car for around several hundred bucks.
Old Feb 11, 2004 | 09:39 AM
dmitriy's Avatar
the car is gone! sold it locally for $850.
Lakersallday24
Jun 16, 2019 01:35 AM
morteljc
Wheels/Tires
Oct 22, 2015 08:43 PM
morteljc
Oct 19, 2015 10:47 AM
kirkhilles
Aug 8, 2015 10:53 AM
silver_i35
Aug 3, 2015 11:23 PM
