throtle body's help
just wondering can throttlebody's be swapped from same year or later pathfinders maybe have a lil more flow to them? or a site that has throtle bodys for a sohc gxe? also looking for intake manifold and headers prefered brands? thanks :) a gd on throttle bodys and spacers would be nice also mass air meters might be usable also bigger is better >.<
I believe your SOL on this one. However there is a trick thats pretty popular with the turbo 240sx guys, they use say a 3.5" diameter pipe (stock is ~3") and put the actual MAF sensor in it. They have dynos proving they got better results using the modified MAF and stock ecu than using a JWT ecu and stock MAF.
thanks if u could post a link of a pick of that or post a pick would rly help :) so i could see it sounds simple enough maybe even makin a bigger one:))
I think it would help out NA cars. I would try it but I dont have a spare MAF.
Going too big could make you run lean, I wouldn't go more than 3.5" with out a way to monitor the engine. I'll try to find a link :) |
having a bigger maf and throttle body would be a nice gain :) just need to find out if they make any for my modle max :/
Going too big could make you run lean, I wouldn't go more than 3.5" with out a way to monitor the engine. I'll try to find a link :) I have a spare MAF and it could be yours for the low low price of $40+shipping :grinno: Oh, btw, did you get that test pipe? |
Originally Posted by Brad92SE
No, unfortunately no one makes larger throttle bodys for our cars. You can, however, port and polish the inside. Basically take a dremel and grind down the inside on both side of the plate and port match the intake manifold. Aaron has a very good writeup on this.
Originally Posted by 89maxSE
I have a spare MAF and it could be yours for the low low price of $40+shipping Oh, btw, did you get that test pipe?
I just bought 4 new bolts, washers and nuts for it. Great job packing it too btw :thumbsup: :wall: mah kar i5 m@DDd fastt know, y0OO! :D |
Originally Posted by doomtoo
I don't know anyones real name, where is the write-up located, or is it under a different name in the faq?
lol, yeah. btw, what are those welds on it for? lol
| All times are GMT -7. The time now is 05:06 PM. |
