Help. Can't find fuel pump relay 92 GXE
I want to replace the relay and test the fuel pump pressure before replacing the pump since it costs $300. Can anyone specicy exactly where it is. I have the Chiltons manual but can't find it.
thx, Matthew |
I'm pretty sure its in the trunk. Take off the panel around your inside around your tailights and see if its in there. You could always get a walbro fuel pump if you had to replace it. They are a lot cheeper. Dont know how the install is on them but I see people w/ them all the time. Good luck
Remove the trunk trim near the left tail light at the bottom of the trunk opening. The fuel pump relay is there.
thats what i was pointing him towards but just wasn't positive if that was the fuel pump relay or not. :thumbsup:
Thanks, Problem solved it was the fuel pump
I didn't actually replace the fuel relay instead I tested the pump to make sure it was getting power when the key was turned to on, it was. Then I pulled the fuel line from the engine side of the fuel filter. I drilled a hole in the lid of one of those free big plastic cups places are always giving away. I put the line in the lid of the cup and turned the key to on. The pump should have primed at that point but nothing came out. I tried starting the car just to make sure, but no fuel. Pump was bad. Replaced it and as soon as I turned the key to "on" the pump primed and the cup filled up about 1 inch with fuel. The max is back on the road.
Thanks Matthew |
| All times are GMT -7. The time now is 07:27 AM. |
