Maxima Forums
Maxima Forums (https://maxima.org/forums/)
-   3rd Generation Maxima (1989-1994) (https://maxima.org/forums/3rd-generation-maxima-1989-1994-8/)
-   -   HELP! car won't go into gear........... (https://maxima.org/forums/3rd-generation-maxima-1989-1994/225728-help-car-wont-go-into-gear.html)
5 ltr. beater Apr 28, 2004 07:45 PM
This just happened tonight; I went to go start my car and as soon as i put my foot on the brake, a buzzing noise comes on and the car won't go into gear. I'm like "wow, you don't see this everyday." I have to manually put it into gear by pressing the red tab at the bottom of the shifter.
has anyone ever had this problem before I take it to Nissan to go find out what the problem is. :deezo:
ChrisCheezer Apr 28, 2004 09:03 PM
do u hear the little ticking sound from the shifter when u press the brake? (u should)
i know this sounds crazy.. but check all ur tail light bulb harness carfully and see if any lines are melting/shorting out. (if this is the problem) this will make a short in ur car and prevent u from shifting.. u may have to replace the tail light fuse or somthing along with the bulb harness.. (2.99, auto zone).. haven't had that problem in a long time so i forget.. but check ur tail lights!
good luck
5 ltr. beater Apr 28, 2004 09:45 PM
good luck
so someone has had this problem before; andf I thought I was nuts. thatnx Chrischeezer, i'll go check them right now and post back in a while.
5 ltr. beater Apr 28, 2004 09:52 PM
ok this is weird, but the noise is now gone. I wonder if this has something to do with my car being parked next to the sprinklers earlier before all this happened. The buzzing sound is gone but I dont know for how long. I'm guessing something got wet and now it's dry. Thanx guys for your help.
maximagxe90 Apr 28, 2004 11:04 PM
good luck
Hi,
i have the same problem as him,
when i first start the car and push the brake the shifter knob is hard and it will not let me move into gear, so i have to push the shifter lever button in order for the shifter to move into gear,
i can hear a ticking from the front of the car does it mean there a tail fuse burn out?
if the tail light fuse is burn out were can i look for that?
is it inside the car in the fuse box or in side the engine bay,
can you please give me some advice or solution it would be appreciated,
thankyou,
eric93SE Apr 29, 2004 06:25 AM
Originally Posted by maximagxe90
Hi,
thankyou,
The tick sound when depressing the brake pedle, is a small actuator beneath the shifter. It prevents children from hitting the shifter and the car rolling to their doom. That actuator can go bad, but if it makes the tick noise when hitting the brake pedle it is most likley still functioning.
5 ltr. beater Apr 29, 2004 07:08 AM
I understand that part; but what is the buzzing all about? Is it like it was described above by the "cheezer"?
ChrisCheezer Apr 29, 2004 11:57 AM
buzzing? i never said anything about a buzzing?
- is it comming from your shifter?? or the fuse box or the right kick panal?
-maximagxe90 : the fuse box is inside the car under the wheel, in a removeable panal below the mirror contols. but be for u replace any blown fuses u need to find the short, check each tail light harness (in the trunk) for melting and cracking and shorting.. replace that part of the harness.
this is a common problem with 3rd gens. no biggie
(where the heck is my sig.)
sinister Apr 29, 2004 02:58 PM
my dads 93 gxe does the same thing with an auto matic transaxle
ChrisCheezer Apr 29, 2004 05:58 PM
check for shorts in the tail lights....
DMad8724 Apr 29, 2004 06:16 PM
umm charge your battery, and you should be able to shift fine after depressing the brake...its your shift lock, check the fuse for "shift lock" too in your fuse panel, it only works correctly if the battery is fully charged, or so the manual says...
