Maxima Forums
Maxima Forums (https://maxima.org/forums/)
-   3rd Generation Maxima (1989-1994) (https://maxima.org/forums/3rd-generation-maxima-1989-1994-8/)
-   -   If it's not one problem, it's another :( (https://maxima.org/forums/3rd-generation-maxima-1989-1994/243006-if-its-not-one-problem-its-another.html)
aw89maxSE Jul 31, 2004 01:23 AM
Check this out. I just had my thermostat replaced a few weeks ago and since then, the car has been running just fine. I am walking into my house after locking my car and I look back and there is steam coming out of the hood! Pop the hood and I smell antifreeze and look underneath the car and I see antifreeze. Take a look around and see where the freeze is coming from and I came to the conclusion that the main radiator hose cracked. I am pretty sure when you squeeze it, it should be somewhat firm, but when I did it was very soft and I could here air coming from a crack somewhere. I felt around underneath and could feel a lot of freeze from one part so I am pretty sure it's the hose. Looks easy to change. How much we looking for a price on this tube? Anybody had this happen or gone through the process?
Edit:
Do you need to drain to coolant to replace the hose?
goon9 Jul 31, 2004 07:05 AM
Top hose or bottom? Top hose not really, just be ready for mess, the bottom would poor out alot, so you should drain it.
aw89maxSE Jul 31, 2004 07:18 AM
Top hose. Alright, I'll be ready for a mess anyways. So I don't have to drain the coolant at all?
The hose is really soft and squishy.
MaDMaX024 Jul 31, 2004 07:46 AM
if the hose is cracked, it probably leaked out whatever fluid would come out when you remove it anyway, i wouldnt worry too much about it, just be ready for a mess.
