driver's side headlight?
I have a 92 SE,My driver's side headlight is out? But it's got power and the bulb works!
when i turn it on then nothing? it's a mystery to me! any suggestions from anyone would be great! |
Does it have ground?
a couple of possibilities.. there's a fuse for each headlight under the cover in the box behind the battery. Mine has an issue where only the high beam doesn't work on the passenger side. Others have reported the same thing and it's been traced to the dimmer switch having shot contacts. Cure is to replace the dimmer switch. good luck
| All times are GMT -7. The time now is 08:30 PM. |
