Maxima Forums
Maxima Forums (https://maxima.org/forums/)
-   3rd Generation Maxima (1989-1994) (https://maxima.org/forums/3rd-generation-maxima-1989-1994-8/)
-   -   Light output from E36's (https://maxima.org/forums/3rd-generation-maxima-1989-1994/333962-light-output-e36s.html)
Phoenix Dec 16, 2005 09:34 AM
Contemplating an E36 conversion over putting premium bulbs in the stock headlamps, how does the light output from e36's compare with stock?
tripleGmax Dec 16, 2005 09:57 AM
i think my light output has improved tremendously. you could also upgrade the current headlights, i forget the light numbers 9007 maybe....but they make the output brighter.
aw89maxSE Dec 16, 2005 10:27 AM
I thought the output was great, but it seemed to lack a concentrated beam. I didn't like that so off they went :slant:
tripleGmax Dec 16, 2005 10:29 AM
i got a great beam after i flush mounted and aimed them right.
goon9 Dec 16, 2005 03:44 PM
A lit marshmellow is brighter than our headlights.
Jeff92se Dec 16, 2005 04:41 PM
+10000000000 on that bro. Must be like 50 lumins! I had my left headlight out for I don't know how long. I only noticed it when I saw the headlight reflections off the car in front while stopped at a light!
Shade20 Dec 16, 2005 05:31 PM
Yea the stock headlamps are really dim i was thinking about doin a E36 conversion with a 9005-9006 Hid kit.. is it even possible?
James92SE Dec 16, 2005 07:15 PM
Yessir..
I've got E36's with HID's (btw HID's only go on the low-beams)
internetautomar Dec 17, 2005 03:39 PM
I had wagner Brite-lites on my A/T and the light output was much better than the 9004s that it had originally
bulb quality will also affect light output.
a long time ago, we replaced one bulb on my parents subi because it was out, the replacement bulb (el cheapo type) was significantly dimmer than the bulb on the other side which was a few years old already.
in conclusion, try some good bulbs before gooing and swapping the E36s in
yay0 Dec 17, 2005 07:11 PM
The 9007's dont fit in the housing properly. I actually tried it just a little while ago. i have sylvania silverstar 9004s right now but they still dont seem bright enough. I got a 9007 sylvania bluevision just to try it out but the bulb wont let the little locking ring catch the little edge. The difference between 9004 & 9007 is 10watts(45vs55) on the lowbeam and the base of the bulb is a little wider on the 9007.
MrGone Dec 17, 2005 07:33 PM
I prefer these :D
http://www.digitalbeta.net/images/740i/Umnitza/3.jpg
Dougn Dec 17, 2005 08:08 PM
Yayo, you can not swap the 9004 with 9007 directly. Look at the sticky in the 4th gen and see all the details and discussions. In general, 2 things you have to do. 1) File off two snubs on the housing at 8 and 5 o'clock positions (keep the one at 12). 2) Switch the ground wires. Many had done the converstion of the 4th gen and swear by it. Some one here mentioned it worked on 3rd also.
poorcollegeboy Dec 17, 2005 09:45 PM
http://www.umnitza.com/product_info....f8aadda776c175
don't know if it will on the maxima but it is an upgrade for the e36 stock headlights. these are equipped with H1 (i recommend OSRAM Silverstars). Clean cut off. Depos make these for the e36 too but the quality is not as good as ZKWs.
goon9 Dec 18, 2005 09:23 AM
I like these better. Good luck finding another just like it. But it's a perfect fit.
https://im1.shutterfly.com/procserv/...016108NZtmblsI
Aftermarket e36 with halo and h7 plasma projectors. H3 turn illumination and amber led corner marker. Frikn bright brights too.
....Just wish they were hid. If they were that would bump them up to costing $800.
MrGone Dec 18, 2005 09:45 AM
just buy one of the cheaper kits, it's like $240 or something for them
swowlinc Dec 18, 2005 09:54 AM
Id buy those in a heartbeat...with or without hid's. WOW.
95turbo gxe Dec 18, 2005 10:19 AM
not bad I thought of trying that awhile back but just cant stop with the go fast mods
mtcookson Dec 18, 2005 02:24 PM
E36's + Silverstars gave me tons of light.
MrGone Dec 18, 2005 03:44 PM
E38's + HID kit = teeheeheehee
http://www.digitalbeta.net/images/740i/cutoff.jpg
Will Dec 18, 2005 06:26 PM
I decided to do the e36 conversion last summer, and fitted the Silvania Silverstars. You will get a brighter light with the e36 lights because the 9006 bulbs is 55W whereas the stock 9004s are only 45W.
HONKER24 Dec 18, 2005 06:36 PM
Are the turning signals clearly visible on these during the day?
SurraTT Dec 18, 2005 07:08 PM
headlights, on the 2ed gen you cant see anything, im serious, so , i was thinking i might could try some 3 gen lights, can anyone give me the dementions of the whole assembly, it might somewhat fit, i just wont to beable to see, when its raining i really cant see and i have to pull over.
some one sell me some 3rd gen lights for cheep???
if a 3rd gen housing would fit decent, i would just go ahead and get some e36 or something
what do yall think??
goon9 Dec 18, 2005 09:50 PM
what do yall think??[/QUOTE]
If i had a 2gen. I'd put in chevy truck lights. No joke. And you definetly do not want 3 gen lights.
OR I'd put in round dual headlights like the old rally vw's.
MrGone Dec 18, 2005 09:51 PM
If i had a 2gen. I'd put in chevy truck lights. No joke. And you definetly do not want 3 gen lights.[/QUOTE]
chevy truck lights are horrible
goon9 Dec 18, 2005 09:52 PM
chevy truck lights are horrible[/QUOTE]
The new ones are fine. The boxy dimensions would work though.
MrGone Dec 18, 2005 10:01 PM
The new ones are fine. The boxy dimensions would work though.[/QUOTE]
for oncoming drivers....
I can tell when a GM is coming lol
internetautomar Dec 19, 2005 05:38 AM
you can also buy C/K projector lights pretty easily
mtcookson Dec 19, 2005 08:06 AM
Me too... there's always one little marker light out. :rofl:
internetautomar Dec 19, 2005 09:41 AM
watch the rear end of a quest and the left tail light will be out
MrGone Dec 19, 2005 10:05 AM
dude, ever notice how many <2 year old GM's have burnt out lights?
The nice thing about BMW's.... they tell you which bulb is burnt out. That's probably why you never see BMWs with burnt out bulbs :lol:
internetautomar Dec 19, 2005 10:10 AM
my bonnie told me which bulb was burnt out too.
I haven't had any burn out on the montana yet, destroyed yes, burn out no :chuckle:
Loco7 Dec 20, 2005 11:21 AM
Those are the E36 from 92-98 right? Did you have to do any Mods to get the turn signal to fit?
goon9 Dec 20, 2005 11:46 AM
It's not that simple.
It's e36 halo projector headlights molding into the stock corner housing. The illuminated corner was replaced with an h3 projection fog light. ANd th constant on marker was replaced with 4 leds. Then the whole thing is cover with a trimmed up Wade cover...
If you can search, there is another thread all about it.
