Painting Rims while on car
I'm about to paint my stock SE rims, but I noticed on the can that it says to take the wheel off the car. I don't have a garage or access to a lift where I can take the wheels off efficiently. Is it ok to paint them on the car (and thus get some paint on the brake rotors)? Will the pads scrape the paint off when I start braking next? Or will the paint foul the brake system somehow?
Ghetto Style
So, taking the previous advice I was going to jack up the car and take off the wheels one by one and paint them. However, it turns out I don't have the tire iron needed to raise the jack and remove the wheels. Doh! So the project is on hold until next week. As for James' question, I bought white Dupli-Color Wheel Paint and Clearcoat from Autozone, and white sandable primer from a hardware store. I spent a few hours sanding the peeling clearcoat off with a coarse grit, then getting the rim prepped with finer grit (160?). I am going to prime with two coats, then paint 3 or 4 coats of white. The can of clearcoat says to wait a week after painting to clearcoat so that's my plan. Hopefully it'll turn out looking ok. Its much cheaper than a new set of rims / tires anyway
clearcoat
Can you get the clearcoat by itself?
I'm about to try polishing some wheels and was wondering about how to protect them, whether to take it to a paint shop for clearcoat or find some in a can.
any help appreciated
Re: One problem
Yeah, I thought about that cause my front brakes dust pretty badly. I think I am going to clean the front rims every day after I paint them to prevent that from happening. I used a wire brush to get the hardened dust off so any dust that accumulates now should be able to be removed with a wet rag and some patience.
Lakersallday24
06-16-2019 01:35 AM
MAXSE5SPD
08-23-2015 12:06 PM
