Maxima Forums
Maxima Forums (https://maxima.org/forums/)
-   3rd Generation Maxima (1989-1994) (https://maxima.org/forums/3rd-generation-maxima-1989-1994-8/)
-   -   Weird Headlight... (I wouldn't say problem?) (https://maxima.org/forums/3rd-generation-maxima-1989-1994/536646-weird-headlight-i-wouldnt-say-problem.html)
Pearl93VE Sep 15, 2007 09:49 PM
Okay so I think there is a short in my system but I have no clue what would make my headlights do this...
High and low work perfect, but when I pull my blinker stick in to flash someone, some wattage goes to the high beams, as WELL as regular wattage to the low. Then If I fiddle with the blinker stick they'll go back to normal low... think it's just a bad blinker stick mechanism or something? It puzzles me...
here is a vid:
http://youtube.com/watch?v=9XyOdPk7WaE
internetautomar Sep 16, 2007 06:34 AM
sounds like the switch is having problems.
take it apart and clean it.
helps Sep 19, 2007 03:49 PM
i pulled mine apart to see what was wrong with it and figured id just buy a new one after seeing it, but after i stuck it back in worked perfectly, maybe something can get jammed in there?
MissingNAxion Sep 20, 2007 08:56 AM
man, that looks like a bad blinker stick as well as the wires with it, i would look for another one in a junk yard and try that out.
Pearl93VE Sep 20, 2007 10:24 AM
Ah, Good thing I have a parts car 20 feet away :)
MissingNAxion Sep 20, 2007 10:26 AM
"Ah, Good thing I have a parts car 20 feet away :)"
You wanna give me a hub cap cover,,,ill buy it from you?
Pearl93VE Sep 20, 2007 10:50 AM
I'll PM you.
Matt93SE Sep 20, 2007 11:00 AM
Yup.. headlight switch itself is going out.
you can try cleaning it and it'll get better for a little while, but it just comes back..
Mine's even worse right now..
turn low beams on and I have a right side light only.
flip my highs on and my right side goes out, left lights up.
homemade wig-wags!! :wall:
I have a new switch sitting in a box, just haven't had time to install it. better do it soon tho- my inspection was up in July. doh.
I also recommend buying a new one. they're about $60 from the dealer, but I've heard you can get them aftermarket too. if you get one from a junkyard, they're just going to have problems too- especially after sitting in the weather. for days/weeks/months. mine worked just fine until I let the car sit for a year when I blew the engine. it's had problems ever since.
