Automatic trans preventative maintinance.
#41
Just out of concern, I recall reading an article online about the life of standard transmissions for the 92-94 Maxima only lasting approximately 100,000 miles. Is this really the case if you shift properly? The article also mentioned that the life of these transmissions was "due to overenthusiastic driving."
#42
Do you have the url link to this article?
#43
You mean my transmission was supposed to break 90K miles ago?
My car spent the last 16 years fighting Seattle traffic as in constant stop and go, which is tough on any transmission. It still shifts today at 190K miles, like it did 10 years ago. Nice and solid.
I don't abuse the car, but I don't granny it either.
If you do proper maintenance (change/flush the fluid) and avoid neutral drops, the transmission will easily last beyond 150K - 200K miles.
The challenge now is finding a well-cared 3rd gen with good maintenance records.
It's pretty hard to find a 3rd gen now with less than 100K miles.
Cars with rebuilt transmissions can be a gamble too depending on how good the rebuild was.
#45
The thing that bothers me, as well as Gapboi is that people have 14-20 year old VG-ATs, never take care of the trans and then go talk crap about it on how bad it is. People should try taking care of it and moving on with life instead of critizing it how bad it is for not taking the abuse they give to it. btw my rebuilt trans is approaching 20k miles, better go get my flush done
Sorry had to vent out on all those talkers
#46
1: Transmission fluid doesn't get changed by most folks as often as it should, if it gets changed at all.
2: when most of those who do get their fluid changed: How much fluid does the transmission hold? How much actually drains out when you pull the plug or drop a pan (on other trans)? Ok... drive until the next change (when ever that is) and repeat. Is that how you would change your oil... leaving half or more of it in everytime you change it? Flush out the fluid when you change it... it's too easy not to do it.
3: With #1 and 2 in mind, heat kills trans fluid. Transmissions die from dead fluid. Hot weather, traffic, towing (maybe not in a Max), hilly driving, "enthusiastic driving" (and any combination) get the fluid hot and it doesn't last as long. If the fluid doesn't get changed often enough... neither does the trans.
4: Most of us here bought our Maxes used. With #1,2, and 3 in mind, let's buy a used car, not change the fluid, go out and see "what the car will do" (read "beat on") on a daily basis- or every other day- and then get suprised that the trans fails at less than 300K.
The trasmissions in my Brother's family's last two cars died prematurely. You couldn't get the 89 Accord to smoke or use oil at 200K no matter how hard you tried, but the trans died at 160K, and the '97 Chrysler minivan's died at 105K. (about $1100 each) He doesn't keep up with that stuff. I try to for him, but I'm busy too, ya know.
#47
certain transmissions have inherent design flaws in them.
the chrysler you bring up is a great example.
chrysler designed it very poorly and never fixed the flaw so to this day you still have a very likely chance of throwing your differential pin through the trans case. that is regardless of how it was maintained. ford has /had a similar issue on it's equivalent transmission except it didn't throw parts through the case, it just won't move.
#48
Has anyone installed the VB shift kit on their tranmission without any major maintenance on it? (major = rebuilt/reman or whatever else)
#49
Is it necessarily bad to install the VB mod on a tranmission where the clutches/bands may already be worn/overly used? Not saying Big's AT is on it's way out or anything, just asking. I was going to send my AT into a local tranny shop to do it, but they said it wasn't a good idea for a transmission that may already have clutches/bands in under-average condition.
#50
2nd Gen Boostinator
btw i do have that vb spring for the re tranny they sent me both springs, and i could send out the drill bit as well 5dlls shipped with a photo copy of the installation manual. you wont get the pump seals tho, im keepin those lol.
heres your tranny valve body info with the spring and where it goes.
the rl stuff in sin the 2nd gen forums.
#51
What is the recomendation on a transmission flush vs. fluid change? Most of the people who have high mileage VG autos have had flushes. Wouldn't changing the fluid a few times close together have the same effect. My tranny has 114K, other than a slightly rough 1-2 shift(could be engine mounts, hope it is) would it be too late for a flush. Fluid has been changed twice in the last few months with no problems.
#52
I was looking through TXchange's website and they actually sell a fully reman'd AT for about $1300, which includes the SK, i believe. What do you guys think? I was thinking, if I were to spend 1300, I'd rather go VE5.
#53
new guy here....i drained the trans fluid on my '92 gxe thsi past monday. 3 quarts came out and three quarts went back in. Im going to repeat in about 3 months. Anyone know the total capacity of this transmission? BTW, my '92 gxe is pushing 140K
#54
I suggest you change the fluid again much sooner then 3 months,depending on your driving habits/how much you drive,swap the fluid out again in a few days,or a week,then again in the same time frame, ending up at 4 changes in the end.
#55
7 7/8 quarts per factory service manual..
I was thinking about doing that. I drive about 35 to 40 miles 5 days a week. I'll repeat tomorrow.
#56
I have a question on this
I'm a 21yr old kid in the bay area attending college. I recently wrecked a car about a month ago and now I'm in the market for another. I found a nice maxima but the only problem is the tranny is going out on it. I could goto the JY and get another for resonably priced the only problem is that I have never done anything this major before and I'm just thinking I'm biting off more then I can chew... I have no place to store it to work on it.... what should I do? should I just walk away and not buy it? it's 500$
#57
#58
2nd Gen Boostinator
ooooh hows the rest of the car, i would ask the seller what exactly he or she think it is, and what does it do to not work(slipps, shurs off engine in gear, ect.ect) then see how much a shop wants to fix it. if you had a place to store it i would swap it myself.
#59
#60
I ended up buying the car. I'm excited
I got a shop to quote me at 570$ in labor if I supply the tranny, great guys, done work for me in the past at really resonable prices (problem is I would much rather have a new tranny if they still made them).. 1 more problem is, the car wont hold a charge. so add that to the list. as the car condition. it's amazing, it's just dirty... needs to be cleaned, I have pix of what the seller posted but i'll post some pix later today... I was able to shift through all the gears easily in my test drive, problem was it would switch into 2nd if i put it in second, but if i put it in drive it would just stay in first and not go any higher. I did hear some grinding while driving on the passenger side and I hope its the tranny and not a transaxle.
#63
that is still considered a transaxle too. transaxle = Transmission and Axle in one assembly.
I had an 86 GL10 Turbo 4wd (AWD didn't arrive until 90 in the legacy). fun car with a turbo.
though I think my legacy is a bit more fun even w/o a turbo.
#64
you're right, it was FWD with 4WD engage.. thanks for the info
#65
#66
eh, might be where i live (bay area) but i suppose i could call a few more places... thanks for the tip
#67
The average shop in Chicago has a labor rate of $75/hour and they cannot charge taxes on labor. Pulling a trans at a shop shouldn't take them more than 1.5 hours, installing it should take a lil more but still $570 is a lil ridiculous for labor..IMO. Glad I helped a bit
#68
If anyone knows anyone in the bay area thats more reasonable to this price, let me know. they charged me 100$ to replace an axle in my GL and I thought that was good considering all the other mechanics in the yellow pages were charging 200-250
#70
On the subject of maintaning your tranny. Everyone clearly reccommends a cooler, but there are mixed replies on fluid. Nissanmatic seems to be ideal, but I read that only synthetic should be used with tranny coolers? Anyone have any advice on what to use?
#73
won't cause a problem if you add a trans cooler.
the only concerns I have regarding trans coolers is that the transmission is supposed to operate within a certain temperature range and a cooler will potentially cause it to run too cool or more accurately, not warm up fast enough for optimum efficiency.
#74
trans flush question...
Hi guys!...this is my first post...I bought a gxe in 94...and love it. Found this forum last week which prompt me to get a trans flush ...as it only has 75k miles on the clock.
So i took it to the dealer...and was supprise that they did the flush but did not change the pan gasket and replace the trans filter???
On the invoice ...lists a something called a trans kit...from talking to service is only an cleaner additive...???
Good site...hope to learn more in keeping one of the best cars Nissan has made...
Starrider ...or Star
ps...if i posted this in the wrong place...not familiar with this forum yet...
#75
#76
a trans kit is typically a filter and gasket, but on the GXE the filter is deep within the trans and generally only replaced when the trans is rebuilt. The trans also lacks a lower pan like a normal trans.
#77
so the tranny won't upshift past 1st, i have all the other gears... anyone have a clue what's going on? woulda kinda help in repair... still not sure if I wanna rebuild mine or buy a used one (rebuild is looking expensive)
#80
and of course switching to 1st manually causes a jolt in speed
