Max won't start
I just had my alternator and battery replaced about a month ago and my max has been starting and running fine, but this morning i got in my car to go somewhere and it wouldn't turn over, it didn't even try to turn over i turned the key and it didn't do anything no noise or nothing. All the lights turn on and work but when i turn the key nothing. What i am thinking is that it is the starter but i was wondering what some people think before i take it to the dealership and get ripped off.
Originally Posted by 1990maxGXE
(Post 6264736)
I've got the same issue just been too lazy to change the bushing. Currently all I have to do to make sure mine starts is bump the shifter up a little to be sure its in park.
Originally Posted by nc90gxe
(Post 6264951)
okay so the max sat in the garage yesterday, and i didn't try to start it. Today i tried to start it and it started right up. So im assuming my new alternator is bad would i be correct?
(Post 6268294)
2. make sure battery is charged (check with multimeter or have autozone check the batt for you) 3. If all above check out ok, then i would suspect a bad shifter bushing or a slowly dying starter as your cause. Next time it does this no start issue, try to bump the shifter around a little to check for a bushing issue..if no go there, then try tapping on the starter with a hammer, then try to restart.If it starts after tapping, then you found your problem.. good luck. :) |
(Post 6268294)
Originally Posted by VEvolution
(Post 6268382)
i put my money on ur shifter.. do u have an
aftermarket alarm? No the alarm is stock. This may be a stupid question but why would the shifter bushing have anything to do with the car starting? and what is a shifter bushing anyway? |
(Post 6268487)
When the little plastic shifter bushing wears out, it will leave some play in the shifter stalk, then the safety feature built into the car that prevents you from starting the car in any drive gears comes into play, it thinks the car is in reverse due to the shifter slop, hence the no start issue. |
(Post 6268487)
edit: green beat me to it |
oh I see. I have an appointment on Friday to have the Passenger side axle replaced since the cv joint is starting to click around turns as the cv boot broke so i'll have them look at the bushing.
Thanks for all the help I appreciate it :) |
(Post 6268487)
Mine is like that, I just push forward on the shifter and it will start. I think of it as a part time anti theft device. |
would the bushing have any effect on how the car shifts when driving or just when starting the car. The reason I ask is that when the car has been shifting recently its felt weird like its not shifting right or shifting late at slow speeds when it shifts from 1st to 2nd.
(Post 6268572)
Thats what i thought just wanted someone elses opinion on it
(Post 6268572)
(Post 6268511)
its a failsafe. so your car wont start in other gears other then park. if that shifter bushing is worn out, the car may not be sure it's in park even though YOU see it is in park. moving it around a bit engages the park and the car will start.
(Post 6268590)
Just a hint, if you are going to replace the shifter bushing, do yourself a favor and replace both bushings. There is one located at the transmission and one under the car at your shifter.
Use the search engine for more details on how to replace them yourself as this topic has been discussed multiple times in the last few years. Both bushings are less than $5 each. Good luck. |
well the cars getting looked at today so if it is the bushings that are bad ill take your
advice and replace them both thanks |
hey could his ignition switch be no good?
Originally Posted by Wiking
(Post 6269125)
Hey, thosee treadmill guys are just envious as they spend the day sticking to the stick... The automato is great if well serviced. I recorded my trip from tragicomiics to excellence [that is; Connectors cleanup, TPS problem]: http://www.cardomain.com/ride/748507/14 --> p.15
old thread i know but forgive me. capedcadaver sold me the shifter off his old auto trans with a bushing on it. i just got around to replacing it last night the one i took off of my car didnt even have a bushing, i guess it rotted off completely. DAMN what a difference!
(Post 6386355)
yeah i did but the speedometer is still reading weird so i guess that wasnt the problem
(Post 6386913)
I wonder if I still have my old cluster...
(Post 6387153)
Originally Posted by Greeny
(Post 6387446)
Get your lazy *** out to your garage and look for it..:o :shiner:
I still have windows, center console, door panels, for sure. manual shift boot too. |
(Post 6387501)
one of these days I will.
Originally Posted by capedcadaver
(Post 6388163)
how about a shift knob? the leather is coming off mine...
Maybe check your fuel pump. My car did what yours was doing and it was in fact the fuel pump. They tested the sending unit too.
RE: Fuel Pump
This solved my problem. It wasn't doing anything and the starter, battery, and alternator were fine. At first I was just getting a click sound, then later on nothing. I tried jumping the batter and starting, and sparks started coming out the battery and a small amount of smoke. Also I replaced my spark plugs too with NGK BKR6EGP. Prior to this, I replaced the distributor cap, rotor, and spark plug wires...but these parts didn't fix the no-start problem, for me it was the fuel pump. |
Originally Posted by 1993-VG30E-GXE
(Post 6389054)
...................and sparks started coming out the battery and a small amount of smoke....................
(Post 6389054)
Any other tuneup will help to face the future. Smoke empowers all computers, as it escapes, no way to pump it back. Hope it was just battery battery... I guess alt swap is waiting around your corner? Here's some Salt: http://www.cardomain.com/ride/748507/23 |
(Post 6389748)
Its common that fuel pump repair is the only one affecting fuel pump failure...:)
Any other tuneup will help to face the future. Smoke empowers all computers, as it escapes, no way to pump it back. Hope it was just battery battery... I guess alt swap is waiting around your corner? Here's some Salt: http://www.cardomain.com/ride/748507/23 They didn't do any repair on the fuel pump...the guy claims that he tested it and got 'no pressure' or something...I can't remember what reason, but I bought the Bosch replacement and he installed it. Next he told me 2 injectors were blown so I had to replace those at 90.00 a pop plus labor...they were re-built ones. He adds on $40.00 after the estimate as "test for mis-fire". 2-hrs labor for the injectors replacement. 2 hrs labor for the fuel pump. I felt scammed. Next theres a whole in the header pipe so I probably have to replace that...is this a tough job or straight forward? Had I known about this website earlier, I probably would have spent the money on extra new tools and attempted the repairs myself. I don't know about you guys, but I get the feeling that many auto mechanics are possibly the biggest scam artists on earth. (I thought I was a scammer opportunist (I'm a Oil Man), but these guys scam me - they beat me) |
(Post 6390691)
You are the maxima maniac...if that is in fact you that created that monstrosity, ...
(Post 6390703)
Yes, just five yrs of fun, 6,615 illustrations as today. Maniac? Mmm yes, hands start to shake, if no Maxima cake...
(Post 6390757)
now it needs some links to ads :wall:
All sweets remains unpublished. And t hat would create at least traffic. Dont want to do that on CDomain. (Organizationally - whole collection is pile of crap, life happens... Also those pages are hard to read, Cardomain doesn't even contain least minimum text formatting capability :( |
(Post 6390767)
Help me out...
All sweets remains unpublished. And t hat would create at least traffic. Dont want to do that on CDomain. (Organizationally - whole collection is pile of crap, life happens... Also those pages are hard to read, Cardomain doesn't even contain least minimum text formatting capability :( I've got tons of space, and bandwidth available. I can configure you an FTP account so you can just upload whatever you need to without being limited. |
| All times are GMT -7. The time now is 03:45 AM. |
