It's Always Something...
So I just got the car back from the alignment shop after installing the VLSD. Everything is great EXCEPT...the drivers side wheel bearing is definitely shot. :mad:
I got the tranny and the hubs last fall from Todamax's wrecked VE. The front passenger side had taken a decent side-swipe-type hit after it had been rear-ended. Both of the CV axles had been busted in the accident. Upon inspection of the hubs I could tell there was plenty of play in the passenger side bearing so I replaced it. The drivers side seemed fine. Well what I thought was was tire noise from the alignment being completely out-of-whack turned out to be a bad wheel bearing on the drivers side. Kinda sucks since a bearing and two seals is $75 from Brian (still cheaper than any parts store). The only difference between VG and VE hub assemblies is the hub itself. The hub is just pressed into the bearing and is easily removeable with a slide hammer. My thought is: could I swap the VG hub for the VE hub in my old VG wheel hub assembly w/o destroying the (still good) wheel bearing? The write-up I followed said the races will separate when you remove the hub, but when I did it the bearing still seemed to be in tact. I'm pretty broke and have already spent quite a bit on this latest swap, so if I can save myself $75+ I'm all for it. Thoughts on this? |
If it were me and I was in a pinch, I'd spent a few bucks at the junk yard and possibly get a good one. I took 2 ve5 hubs from a car with 260miles and they worked fine and still are on my car. Just a thought...
The junk yard I went to charged me 5 bucks a hub. |
Originally Posted by goon9
(Post 6341360)
The junk yard I went to charged me 5 bucks a hub. Think my idea will work or do I have to bite the bullet and let my rolling money pit bleed me a little dryer? |
the hub has different splines between the VE and the VG so you can't use a VG hub with VE Axles.
Originally Posted by maxitech
(Post 6341344)
...could I swap ... w/o destroying the (still good) wheel bearing? ...
New bearing will also be destroyed if not properly pressed in - absolutely no stress on the bearing inner ring. |
Well, I ordered a new one from Brian, which is still $23 cheaper than the local Carquest...Why must this wheel bearing rain on my parade? :bustrun:
(Post 6342026)
Originally Posted by capedcadaver
(Post 6342091)
something about a lawyer named murphy...
When you just spent $700, it's hard to be happy about spending another $100...but I see what you're saying...Don't worry, I still like the car.
Don't feel bad, I have a d-side wheel bearing out atm..:mad:
To the local j-yard we go..:run: |
Originally Posted by Greeny
(Post 6345046)
New wheel bearing is in, the car has been realigned, and she really MOVES!
(Post 6357141)
| All times are GMT -7. The time now is 11:32 PM. |
