Where did the Maxima lose it's height?
Height
1989-91: 55.1 in (1400 mm) 1992-94: 53 in (1346 mm) What happened? Why is the 94 2 inchs lower than the 91? |
Maybe they got different springs in those years? :gotme: Is there anything specific on those specs though? Like 92-94 SE? Or do those #'s correspond to all Maximas in those year brackets?
where did you get those #'s from?
weight diff?
Probably the SE/GXE spring difference. The wifey's gxe seems to be a little taller then my SE was with stock springs. I know for sure the oem gxe springs are softer compared to oem se springs, her car is cloudy floaty compared to what mine was with the stock springs.
Originally Posted by Greeny
(Post 6683162)
i think the height difference between SE AND GXE is for handling and comfort purposes and plus maybe SE's sports tuned suspension made it lower for better handling.....
http://uploader.ws/upload/200810/hieght.jpg |
Originally Posted by burhan92SE
(Post 6684279)
Originally Posted by 3g94MaxGXE
(Post 6682473)
Height
1989-91: 55.1 in (1400 mm) 1992-94: 53 in (1346 mm) What happened? Why is the 94 2 inchs lower than the 91? I think your numbers are wrong. Can you post a reference? |
(Post 6683162)
This just doesn't make sense to me. It's wikipedia so not the most infallible source but regardless it's still a bit frustrating for those of us who have eibachs and kybs in our closets who don't know if they will get 1.2 inches of drop or what. |
(Post 6685622)
but then how do the Eibach springs lower 1.2 inches? You would think by now somebody would be on here complaining or bragging that his 91 GXE dropped 3 inchs or that his 93 SE gained an inch.
(Post 6684978)
is this noticeable between when you sit down in your GXE vs sitting down in your SE? Like you fall down into the SE moreso than into the GXE?
(Post 6686715)
not really tho.....but i will have to say that, i have two buddies one is actually fat and he weight 240pounds and one is 6.5' and he weight about the same...and they both sit in my car (SE) my car looks lower compare to GXE ( when they both sitting in GXE too )....and i remember once someone was saying something to me about GXE AND SE that '' man GXEs are bigger than SEs and i said NO they r the same:S...but wen i bought GXE and found out that there is a height difference....then i understood wat he meant...GXE is a lil higher then SE (stock) thats why GXE looks bigger, thats about it.....but if u lower them both i think u have to lower GXE a bit more than SE to bring them to the same height....
(Post 6686715)
Originally Posted by maximal
(Post 6688518)
i have a feeling you're comparing an SE with a sunroof with a GXE without one. the sunroof takes up more space so the headliner may seem closer to your head.
Just out of curiousity...Has anyone ever seen or owned a Maxima with the "electronicly adjustable" suspension? I have been asked on several different occasions when buying parts if my vehicle was equipped with such. But I personally have never seen one or heard anything about that.
Originally Posted by Jon94SE
(Post 6692820)
| | | | | v |
| All times are GMT -7. The time now is 12:28 PM. |
