High Temp Paint didn't Do Crap for My VG Muffler Assy
By the way guys, I was inspecting my fully painted exhaust system the other day from back in the summer, from 1 salty winter, and it's already rusting on the flanges and the weld spots. It's not rusting through, but I thought from 3 coats of the high temp paint, it could create a barrier to the corrossion.
As far as I know the Maxima's in Canada had Bosal Exhaust systems as OEM...but what I don't get is how the original lasted nearly 16 yrs. |
Originally Posted by 1993-VG30E-GXE
(Post 6960034)
rust usually starts on the inside and works it's way out.
(Post 6960385)
it's going to rust no matter what.
only thing you're doing is slowing it down. |
Originally Posted by DanNY
(Post 6960650)
only thing you're doing is slowing it down. Unless you powder coat right from the get-go |
Originally Posted by Garf
(Post 6961035)
:sprint:
(Post 6961103)
you would have to powder coat the INSIDE of the pipes. 99% of all rusted exhaust is from inside where the exhaust flows and the water settles.
(Post 6961120)
is that even possible? before or after bending the pipes?
:gotme: |
(Post 6960044)
in for pics? my engine block is rusting through the paint a little bit... like, the rust is weeping down in some spots. it's got high temp paint on it also, but i guess the rust is a determined mofo or something, trying to push through at all costs.
(Post 6961103)
(Post 6961035)
:sprint:
(Post 6961390)
just drive WOT so the exhaust gets hot enough so all the water gets burned out from condensation. :D
the more miles put on a car per year the longer the ORIGINAL exhaust will last. |
(Post 6961472)
or long enough.
my stock muffler is still in good shape, but my old cat flanges were just disgusting
http://i164.photobucket.com/albums/u...h_IMG_0079.jpg |
I sprayed some 1200*F duplicolor on a header to see how long it would last...I thought it would last about 10 minutes and it stayed on the header until I removed it and sent it in to be ceramic coated (roughly 6 months!!!!). So I'll try that on my custom ypipe first just out of curiousity and if it starts peeling I'll ceramic coat it like all the rest of my exhaust headers
Originally Posted by CMax03
(Post 6961795)
(Post 6961811)
i wonder what goon used on my exhaust manifolds because the block is fine but the exhaust manifolds basically burned the paint off in just a week or two.
Just got back in from spraying the under-body with car wash soap and rinse, to get all the winter road salt off. I'm amazed at how well the grease stood up to the salt, even though in the fall I used the cheapest grease I could get. I pretty much greased any exposed metal by hand AFTER first spraying with used engine oil. The exhaust flanges are rusty but like you guys said, you can't prevent it if it isn't stainless. The Rustoleum High Temp spray paint stood up, and didn't flake off.
So what I found was, the Quaker State Multi-Purpose Lithium EP (NLGI-LB) didn't stand up as well as the cheap Walmart SuperTech Lithium EP-2 Moly (NLGI-LB). The quaker state stuff washed off. Don't know if it's because of the Moly, but those were the results. Next time I grease i'm going to use the Marine MP grease so I don't need to reapply for sometime. Photos soon when I complete the injector early this week. |
(Post 6961778)
| All times are GMT -7. The time now is 06:22 PM. |
