Good quality fuel injectors
how makes good fuel injectors?
Who makes the Nissan Japan injector? |
Bosch from what I hear is the best.
Currently, I'm using Beck Arnley injectors and they're holding up pretty well. They look the closest to OEM. Stay the hell away from Python injectors. |
Just buy new, and don't have to deal with the hassle of a reman - I bought Bosch....don't know if they are the best. Yellow Dot, Pink Top = $114.00
So far thumbs up on two brands.
On 93GXE, one injector has an open circuit. Is the valve stuck open or closed, gas leaking in or stuck shut? Replace 6 or just the bad one? |
Originally Posted by OnTheRoad
(Post 6973867)
Who makes the Nissan Japan injector? buy new.Get them from internetautosupply (i think thats his name) Dont get reman's. I went through 12 in two months until I bough new bosch for a great deal. Good luck. |
(Post 6974080)
What's the typical life on the fuel injector? In mile and years? Has the EtOH rich gas shortened the injector's life?
I notice the insultation on the injector wires are cracking. Any good place for replacement harness or wire sets? The engine has overheated about 5 years ago. Did warp head, but some indication on tensioner, trace of melted rubber from timing belt. |
A friend of mine bought a set of bosch and replaced them all since his were the original injectors and left him no worrys about having to replace the others one at a time
(Post 6973867)
Who makes the Nissan Japan injector? I just changed all 6 injectors in my 91 Max with Bosch (new) from Rockauto.com $115 each. Don't forget to order the o-ring packs. The car runs great. Change the 2 fuel rail hoses while your in there with fuel injection hose 5/16'' |
Thanks for all the advise. The Bosch injector were locally out of stock, then when from $120 to $150. Got the Neihoff 57678, which is likely the same as the Borg Wagner (BWD 57678) for $145. The original was with a yellow dot. The Neihoff 57678 replaces both yellow and green dot one. Guess there's not much difference between a yellow and green dot injector. Injector price in CA just when dramatic up in price. 20% to 35% in one week.
(Post 6989074)
http://www.rockauto.com/catalog/raframecatalog.php |
© 2024 MH Sub I, LLC dba Internet Brands
