Something I never experienced
#41
mines is doing the same thing had the alty checked at two different spots advanced auto and autozone,both times the alt tested at spec.had the battery checked and charged put all back together and boom brake and battery lights on again.do any of you guys know where all the grounding points are sorry for the thread jack
#42
Taking my Maxima to the Max!
Just FYI, I recently replaced my alternator with one from the JY for $29. So far so good. The original OEM alty that I had rebuilt back in 2002 for about $116 laster me 7 years. I think that it mostly went bad because I haven't been driving the car much the past 3 years and was trying to charge up depleted batteries by running the car every few months for a while.
I did get a new Napa battery and will run the JY alty until it dies and then get a rebuilt one from Advanced Discount Auto Parts with a lifetime warranty for about $89. Otherwise I might just have my original one rebuilt and use that when the JY alty goes. You might also get lucky at a U-Pull JY and find an alternator that is a recent rebuilt or replaced one. Doesn't hurt to try. Good luck!
Oh, and it's not at all difficult to replace it yourself. All you need is to remove the lower passenger side splash shield, jack up the passenger side or use ramps, and remove the old alternator using a ratchet and 12mm and 14mm sockets and a short extension. If it's dirty with oil don't be afraid to use degreaser and a hose to clean it as long as you let it dry overnight before running it.
CAN-Toronto FS: Emanage Ultimate and plug/play Harness
knight_yyz
11-06-2015 02:34 PM
RWCreative
09-21-2015 11:01 AM
lrb6805
09-17-2015 04:49 PM
