Maxima Forums
Maxima Forums (https://maxima.org/forums/)
-   3rd Generation Maxima (1989-1994) (https://maxima.org/forums/3rd-generation-maxima-1989-1994-8/)
-   -   Can't find the sunroof drain hoses to blow them out. (https://maxima.org/forums/3rd-generation-maxima-1989-1994/641906-cant-find-sunroof-drain-hoses-blow-them-out.html)
Funk-O-Meter Nov 13, 2011 07:59 PM
My roof collects water and drips it on me when it's been raining hard. I know there are drain noses that run down the back roof struts and into the wheel wells that need to be blown out but I can't find where the hoses empty. Where are they?
Laevateinn Nov 13, 2011 08:48 PM
I have this problem too. Anyone?
Maximan190 Nov 14, 2011 06:00 AM
the back drains exit right behind the back tires, behind the splash guards/mud flaps (if you have them) Open the sunroof and pour some water in the drain track and watch where the water drains out onto the ground
CarAudioHelp Nov 14, 2011 07:02 AM
If you know how to access the power antenna you'll find the hose in that area.
cardana24 Nov 14, 2011 09:33 AM
^^ This.
Mine was all rusted and water was backing up. Once I cleaned it out at this point it has been fine.
dj tes Nov 14, 2011 12:37 PM
I have the same problem
Funk-O-Meter Nov 14, 2011 01:47 PM
What do you use to clear the lines out if you don't have airtools?
Funk-O-Meter Nov 15, 2011 04:56 PM
Found the rear hoses and blew them out with a high powered shop vac and micro attatchments. Just realized there's two up front as well. The rear passenger side hose has a second hose attatched to it. Where's this hose come from? Doesn't say in the FSM. Passenger side still not draining well enough.
Chris Gregg Nov 15, 2011 08:06 PM
Yup, there are front ones too. Travel hidden inside the a-pillars.
Hectic Nov 15, 2011 08:15 PM
If I had this problem the last thing I'd be worried about is water dripping on me.......
DizZL3 Dec 11, 2011 04:10 PM
Can you blow out the back ones from up top with it open? Mine seems to just leak on the passenger side back seat right by the handle above the window. Or could it possibly the seal isn't stopping enough water? I know its not totally going to seal it off but it only really starts to leak in if its raining really hard or if I go to the car wash. Is there some adjustment for the sunroof that I don't know about?
