tach trouble
Does the tachometer run from the tcu?
Don't have my fsm but it can be wiring into the input of the ignition capacitor...
Originally Posted by CMax03
(Post 9057009)
So i thought maybe the tcu was the issue because i swapped it. But i swapped back in the old one and tach is still not working. Being that was all i swapped i figured start with what i did because it worked before swapping the tcu. I checked to see if maybe i accidently unplugged or disturbed something in the proccess but from what i see everything appears normal. What could cause the tach to stop working and all other gauges are fine? It's a 92 vg. Any suggestions?
Have you tried tapping on the Instrument cluster? In my third gen I had to bang on the cluster to get it to work.
Originally Posted by lux97Max
(Post 9057516)
Originally Posted by ac max 92
(Post 9056953)
Originally Posted by Hectic
(Post 9057797)
No, the usable signal comes from the ECM. There is a condenser circuit prior to the ECM. But your problem is a faulty tach, just replace it.
I also put in a new ecm along with the tcm and put in yet another ecm thinking it may have had something to do with it being that prior to replacing the ecm the tach was working. I had originally replaced the ecm so i could get the timing set back to normal being my other ecm was chipped by a tuner and after having the distributor adjusted it threw off the timing causing a mis. Can the tach itself be replaced without swapping the entire cluster? If so how easy is it to do without buggering up my cluster? I wasn't sure if the tach got signal from the speed sensor at the tranny or the distributor or what. I've checked for any lose or bad connections after replacing the ecm but everything appears to look o.k |
(Post 9057802)
(Post 9057820)
Yeah, it's easy to replace that tachometer itself. Just remove the cluster, remove the fascia, and there's a couple screws on the back that hold the tachometer in place, remove those and you can swap it right out.
(Post 9057820)
© 2024 MH Sub I, LLC dba Internet Brands
