vg fog light plugs
I have aftermarket foglights and looking to remove the previous wiring job and go with the factory wiring harness. Mine didn't come equipped with factory fogs but all the wirings there in the factory harness. Could anyone post a pick of what the factory foglight connector looks like from the foglight side or let me know if there are other connectors on the car that are the same that i could cut off a scrap car so i can make my aftermarket fogs plug and play with the factory wiring. Thanks. If im not mistaken it's a female connector on the foglight side?
Your car should be pre-wired for oem fogs.check around to see if there taped up under the bumper. Also check to see if you have the fog light button inside the car or plug.if you don't see a button remove the blank square on the dash to see if there's a plug connector for fog light button behind there.
Originally Posted by lux97Max
(Post 9060649)
Hi Lux, As i was saying i already know all the factory wiring is there but i have aftermarket foglights on mine so im going to have them connected to the factory wiring i just need some connectors and pigtails from the oem foglights to make my aftermarkets plug and play. |
3 Attachment(s)
You can get the connectors from the turn signal lamps, so that you don't have to find and ruin a set of fog lights. I'm sure they can be found on all sorts of models from the same period.
Attachment 16445 Edit: Forgot that they are keyed. So you will have to shave some plastic from the connector. This is why it's a good idea to take pictures. Attachment 16446 Wrap the wires with loom or some equivalent. I used scrap insulation from a cable because I didn't have any small diameter loom at the time. I don't like how it looks (doesn't look factory), but it does the job. Attachment 16447 |
Great. Good to know they're the same as the corner lamps. I actually have an extra set of stock corners with harness i can use the connectors from. Thanks for that info and the pics. Hectic. Much appreciated :)
Not the corners, the turn signals, on the front bumper.
Originally Posted by Hectic
(Post 9061073)
Got it! Maybe i should have opened my eyes :eek: and read that more clearly lol. Thanks Hectic :) |
© 2024 MH Sub I, LLC dba Internet Brands
