Reman power steering pump
Hi Guys...
Had Service replace power steer pump. Service writer said tech said it was leaking ...so i ok it via phone. The car steers quietly while moving however when stopped and turning the wheel either way ... a slight noise is heard some times again only when wheel is turned a quarter way? Any ideas as to what is the cause? Thanks in advance :) |
Originally Posted by Starrider
(Post 9170737)
Hi Guys...
Thanks ac max 92 !!! Told service writer about this issue... there protocol is for customer to go over this with the tech that worked on the car? Not just another mechanic.
The technicians at a dealership are paid by the job, not by the hour. If they have another tech work on the car, they have to pay him. So they get the original tech to fix it and they don't have to pay him again.
Thanks DennisMik for the info...
Hopefully you just need a little more tension on the belt. Keep us posted with what the dealership does and if the issue got fixed. They should make good on their work.
I know you probably fixed this but what kinda of noise was it grinding or squealing
likely just last bits of air making its way out of the system or belt noise
Hi Guys...
Took car and noisy pump back to service...They replaced the 'new rebuilt' pump with another 'new rebuilt'...they had installed. Their is no more noise. There was no charge for new part and replacement. However if the second pump is defect...they wrote that if the pump needs replacement again...labor will be not guaranteed something to that effect. :) |
Glad to hear you got it sorted out Starrider. Good to hear they made good on their work. They should warranty parts and labour it's not your fault you got a lemon pump and if it's their own product they're using and not aftermarket then nissan should look after the labour too for your troubles no matter how many times within their warranty period which should be at least 1 year parts and labour..
© 2024 MH Sub I, LLC dba Internet Brands
