Timing belt replacement parts or kit recommendation
1994 Maxima GXE. 130K miles.
belt or kit recommendations what should be replaced at the same time also. |
Camshaft seals, tensioner and tensioner stud, crankshaft seal, thermostat, water pump.
2nd page in the 3rd gen classifieds. Looks like aminus21 has alot of your parts your looking for. Might be worth checking it out to see if he still has them? Price was great for all the stuff he had.
tried contacting him. got no response.
Originally Posted by markevans999
(Post 9188481)
Gates tck104 kit on amazon. What I used. |
Here are additional some Nissan Part Numbers, if you need them:
Timing Belt Tensioner 13070-42L00 $70.13 TB Tensioner Spring 13072-V5210 $2.45 TB Tensioner Stud: 13073-V5001 $2.43 Thermostat 21200-V5015 $17.19 Crankshaft Front Seal 13510-88G00 $5.73 Cam Shaft Seal 13042-D0101 (2) $9.66 Water Pump 21010-16E03 $93.44 Timing Gear/Sprocket 13021-0B700 $32.70 Crankside Plate 13022-V5001 $2.40 $2.40 Front/Snout-side Plate 13023-V5000 $3.77 Other considerations: 3 drive belts Antifreeze I always replace the tensioner when I replace the belt. The 94 had a different timing belt than the earlier models. Just that one year, 1994. The rib-style of the belt was different. Make sure you are very specific about the year when searching. I went with a Gates timing belt and had good success. I have two different part numbers for the Nissan timing belt, but I'm afraid to post them because I can't remember which one is which. If you want to go Nissan specifically then call your local Nissan dealer and specify the year for the right part. |
© 2024 MH Sub I, LLC dba Internet Brands
