No spark & no fuel 1991 max
i have a 1991 nissan maxima 5sp,the car has 145xxx miles. It always ran like a champ,until one day i was slowing down approaching a red light then it just died. I pulled the the spark plug boot & did the spark check and it had no spark, so me and my dad changed several parts such as the igniter ,distributor & the coil and it still has no spark. Also i do not hear my fuel pump cutting on anymore when i turn the key. With that being said my dad told me that it may be the computer,so i ordered one off ebay from a automatic maxima,i could have gotten a 5spd cpu,but the only place that had them was rock auto and they wanted $250 for it ,and i really don't feel like dishing out all that on a part that is not guaranteed the problem.
So here are my questions: 1. Has anyone ever had that problem? 2. Is it the computer? 3.What else should i check after i install the computer if this problem persists. |
have checked all your fuses?
@tiniform yes, me and my dad went over it this weekend & he says it might be the cut off relay in the trunk. we used a test probe & the coil is not firing. so we got a new coil & it still didnt work, were can i get the orange relay from?
do you have a wiring diagram? instead of throwing parts at it, search for the wiring diagrams for the fuel pump and you should be able to trace back and probe points for power.
long shot but are you for sure the timing belt didnt break? that could cause a no spark and i guess possible make the fuel pump kick off if the ECU doesnt like it |
no ,its not the timing belt,we checked that . & we pulled up a wiring diagram on shopkey ,but it sucks.
Distributor timing diode went out (Cranksensor)?
Originally Posted by CMax03
(Post 9190440)
is it no spark or spark is not happening at the right time?
how did you exactly check for spark? how did you install the distributor? it's known that the FSM is wrong in installing the distributor back in the motor. for the fuel situation...spray a little starter fluid down the intake. it should run for a few seconds so then you can rule out fuel. concentrate on the spark issue for now. hate to state the obvious but i assume you have a decent of spark plug wires in there and the cap+rotor are in good shape? |
Originally Posted by ac max 92
(Post 9190462)
Looks like in his 1st post he mentioned he changed the distributor. Looks like he also changed the igniter and coil. O.p if you search here on the forum there should be a link to the FSM which you should be able to find the wiring diagram. I had a box full of relays and fuses months ago but they're all gone now. Had this come up some time back I could have shipped you some. Have you checked the scrapyard or classifieds here to see? I believe theres a recent part out in the classifieds. Might be worth checking there for your relay. I'll check to see if I may still have a couple kicking around. If you want to post a pic of the relay you need. Also you mentioned you checked the fuses. Did you happen to check the main 30amp green fuse under the hood? Were all fuses good? Maybe you have a short somewhere?
Originally Posted by DanNY
(Post 9190463)
Originally Posted by red3rdgen
(Post 9190465)
yes,i checked all fuses under the hood. and thanks for your help. let me know if you have any relays.
is it a specialized relay? if it is, try going to a self serve junkyard like Pick N Pull and get one for $2. if its a generic sized relay, you should be able to get a universal replacement from an autoparts store or swap it with another relay just to test if its the issue
Run straight power to the fuel pump and see if it powers up? Check the relay input (signal) and output (load), check the coil for power and the igniters for power, Just cause they were changed doesn't mean a thing! Test your wiring!
finally got it started ,it was a damn 10 amp fuse,smh i was about to junk the car over a 10 amp fuse lol
and my maxima is maroon like your in that pic, but im missing my spoiler lol ,any idea where i can get one?
(Post 9195792)
It's great to know it was something simply overlooked....
© 2024 MH Sub I, LLC dba Internet Brands
