are there any 12 volt constant power in the back
I am trying to put an after market antenna and the instructions are bad... The stock wiring harness there are two harness in the back... one has two wires and the other have about 4 wire.... the instructions are un clear... I am basically have no power antenna... so the damn thing is down... it says it needs a 12 volt consistant voltage and another wire from the radio to complete the cycle...
The antenna i got is from a company called RallY , it came with a on/ off rellay... Basically i am just so confused. Do i have to run the wire from the antenna to the radio... or can i just use the harness...? I need to know which one is the 12v power and which is the one for the power for the radio:confused: :confused: :confused: |
trunk dome light??? i know it has to have some kind of power wire to it...other than that try to find a power wire to the tail lights. that's what i would check.....:confused:
Originally posted by pearl93max trunk dome light??? |
You need a multimeter! Makes it easy to find 12V. It should be there on the antenna connector. Check your Chilton's manual. Don't have one? Get one of those too.
© 2024 MH Sub I, LLC dba Internet Brands
