Maxima Forums
Maxima Forums (https://maxima.org/forums/)
-   4th Generation Classifieds (1995-1999) (https://maxima.org/forums/4th-generation-classifieds-1995-1999-43/)
-   -   FS: 4th gen trans with cryo'd/detailed gears, new bearings, etc. (https://maxima.org/forums/4th-generation-classifieds-1995-1999/402025-fs-4th-gen-trans-cryod-detailed-gears-new-bearings-etc.html)
Nealoc187 Jul 12, 2007 09:56 PM
Just finished this trans up tonight. Highlights of this trans are:
1st gear - cryo treated and detailed 5th gen gear (double synchro as opposed to single synchro as in 95-96 transmissions)
2nd gear - cryo treated and detailed 5th gen gear
3rd gear - detailed 5th gen gear
4th gear - detailed 5th gen gear
Brand new reverse idler gear
Brand new 2nd gear synchro
Brand new 3rd gear synchro
Brand new differential carrier bearings (aka side bearings)
Brand new input shaft bearings
Brand new input shaft seal
Brand new striking rod seal
Shift rails detailed and polished for smoother shifting
Hubs buffed for smoother shifting
Sleeves buffed for smoother shifting
Shift selectors and fingers detailed and polished for smoother gear changes
Glass beaded transmission case - so clean you could eat off of it
Case oil modded for more oil flow to input shaft front bearing
Properly shimmed to the following specs:
Input shaft: 1.41mm shim used (1.37-1.42mm req'd to be in spec)
Differential: 1.68mm shim used (1.67-1.72mm req'd to be in spec)
Main shaft: 1.23mm shim used (1.18-1.23mm req'd to be in spec)
OK so here's the deal. Will this trans be stronger than a stock 4th gen trans? Yes. Will this transmission be indestructible? Absolutely not - no one can ever guarantee that about any trans. What I can guarantee is that this trans is shimmed properly and that the work above is done to try to make this transmission as strong as possible within the limitations of the tiny, wimpy gears that the manufacturer uses and that the trans should shift incredibly due
Price is $1100 shipped right to your door. I will take care of shipping through Fedex insured ground shipping through my work. PM me. Paypal or cashier's check accepted.
http://i137.photobucket.com/albums/q...en07-12-07.jpg
RIPTIDER Jul 13, 2007 06:18 AM
DIBS, on this one.
what is your paypal account?
RIPTIDER Jul 13, 2007 06:23 AM
is this open diff or vlsd?
matty Jul 13, 2007 09:19 AM
Second Dibs. Seriously.
Open or Locking ??
RIPTIDER Jul 13, 2007 05:47 PM
Payment Sent!!
Nealoc187 Jul 14, 2007 01:11 PM
Sold to riptider - I'll have another for sale in the coming weeks.
BlackMaxGTR Jul 14, 2007 01:15 PM
tranny
will it b exact same setup and 1000 cheaper :chuckle:
ashazad Jul 14, 2007 10:41 PM
trans
i am looking for a non locking transmission, do you have one??
