Maxima Forums
Maxima Forums (https://maxima.org/forums/)
-   4th Generation Maxima (1995-1999) (https://maxima.org/forums/4th-generation-maxima-1995-1999-6/)
-   -   Corner Lights Don't Work!!!!!help (https://maxima.org/forums/4th-generation-maxima-1995-1999/100394-corner-lights-dont-work-help.html)
MAXXspeed18 Jul 12, 2002 05:29 PM
i just tried the lil mod where u shave down the tab on the 1157 bulb and put it in 180 degrees from where it should b (actually i did it like 2 weeks ago wit a xenon bulb) and they worked great until yesterday i switiched to bulbs to what i think were alot less powerful bulbs cuz the xenons were bright as hell......well the lights worked when i first turned them on and everything was cool until when i got bak to my car l8er that nights and all of a sudden they didn't work along wit my side marker lights (the ones near the turn signal) i check to see if i blew a fuse but i don't think i checked in the right place.....i checked the fuse box next to the battery under "RH LAMP" or sumthin like that.....the fuse wuz ok....my car didn't come wit a owners manual when i bought it so i don't kno where the right fuse to the corners are......if sum1 has had this problem b4 or if one of u guys knows whut exaclty iz wrong and how i can fix it....help me out...thanx
JPLW26 Jul 12, 2002 06:12 PM
Re: Corner Lights Don't Work!!!!!help
check the tail light fuse
Ravq Jul 12, 2002 08:15 PM
Here is the owner's manual in PDF format.
http://www.nissan-techinfo.com/deptog.asp?dept%5Fid=37
Have you checked the bulbs?
MAXXspeed18 Jul 12, 2002 10:11 PM
yea i checked the bulbs and everything, there fine, they don't look burned or show any sign of burns on it and i even put the old onez bak on it and they don't work, itz like sumthin blew out but i dunno what
JPLW26 Jul 12, 2002 10:50 PM
i told you to check the tail light fuse on the top left corner of the fuse thing... if that isnt blown... then check the fuse box next to the battery... and see if the tail light fuse is blown there... trust me i did this 2 days ago
