keyless entry: sorry to be repetitive
I just wanted to make sure before I go ahead with a purchase. I looked in my trunk as per a previous post and I have the brown connector for keyless entry. I can just get any old keyless entry system for my 98 GXE and it should work right? I know there are a lot of posts regarding this, but I just wanted to make sure as I'm being paranoid :(
Re: keyless entry: sorry to be repetitive
Originally posted by runelind I just wanted to make sure before I go ahead with a purchase. I looked in my trunk as per a previous post and I have the brown connector for keyless entry. I can just get any old keyless entry system for my 98 GXE and it should work right? I know there are a lot of posts regarding this, but I just wanted to make sure as I'm being paranoid :( |
will have to try that when it is not quite as bright outside...all that happened was that the car beeped at me when I pulled the key in and out. What did you mean by a fob system?
Originally posted by runelind will have to try that when it is not quite as bright outside...all that happened was that the car beeped at me when I pulled the key in and out. What did you mean by a fob system? |
Originally posted by Requin6 you can see the blinkers flash in the gauge cluster (your turn signals)...they will flash twice immediately after you put the key in those 6-7 times. the remote is also reffered to as a fob. all you need is the remote. |
Originally posted by runelind Hmm...that didn't seem to work...what will I have to get if it doesn't? |
Originally posted by Requin6 forget to mention that you have to lock the doors behind you and shut them before you put your key in. try that out. I have a 98 5sp maxima w/o sunroof and with the manual trunk/gas tank release on the floor next to the drivers seat. |
Originally posted by runelind Nope, doesn't work. I have a 98 5sp maxima w/o sunroof and with the manual trunk/gas tank release on the floor next to the drivers seat. |
Originally posted by runelind http://cgi.ebay.com/ebaymotors/ws/eB...tem=1842463412 Would something like this be what I want? |
Well I wouldn't care so much about the trunk release, although I will search for it. Just as long as I can lock/unlock it with the remote is good enough for me.
Thanks for the help btw...you guys truly rock in this forum! :D
Originally posted by runelind Well I wouldn't care so much about the trunk release, although I will search for it. Just as long as I can lock/unlock it with the remote is good enough for me. |
Well how involved of a process is it to install one of these? I was under the impression that they were fairly "plug and play". Don't they just connect to the brown connector in the back?
you can search to see if you can dig up some instructions, i would assume this kit would come with some sort of instructions. you would have to have knowledge of electric wiring and being able to pull out some of your interior.
© 2024 MH Sub I, LLC dba Internet Brands
