Maxima Forums
Maxima Forums (https://maxima.org/forums/)
-   4th Generation Maxima (1995-1999) (https://maxima.org/forums/4th-generation-maxima-1995-1999-6/)
-   -   Lights again - 1157's (https://maxima.org/forums/4th-generation-maxima-1995-1999/11663-lights-again-1157s.html)
1997SENJ Dec 22, 2000 06:59 AM
Hey - I was just wondering -
Will the 1156 bulb fit in place of the 1157? if so, that seems like the easiest way to upgrade wattage of the corner lamps next to the headlight. Am I wrong about this? anybody know?
-Dan
Dec 22, 2000 07:19 AM
I'n not 100% sure, however I beleive that a 1156 is a single filiment bulb and the 1157 is a dual filiment. I beleive that a 2057 is a brighter version of the 1157. Maybe someone with more bulb experience can comfirm this.
tgonza1057 Dec 22, 2000 07:34 AM
i got 1156 on my car
i have had them on for three months and they still work
I30CeFiRo Dec 23, 2000 12:55 PM
Re: i got 1156 on my car
1156 is a single filament bulb while 1157 is a dual filament bulb. They are not interchangeable. :(
ny96max Dec 23, 2000 04:08 PM
i say buy that 2057 bulb to get the look you want. The other thing 1157 is dual and 1156 is single, cannot be done!! without changing the socket.
benny Dec 23, 2000 08:29 PM
1156 bulbs will work fine. take the bulb and file down one of the nibble, and it will fit in the socket. works perfect. and no need to rewire and solder.
xraydoc99 Jan 7, 2001 01:21 PM
Who to believe?
I want to make the corners whiter\brighter to match my headlights (went the inexpensive route with the Sylvania CB's) Sounds like just putting in the 1156 bulb will be easier than doing the rewire. Some post say 1156 will work, others say no way it will fit. Anyone out there who has actually put the 1156 in and it worked for them? For those that say it won't work, what is the reason? Any help appreciated before I go out and spend the money on the bulbs.
benny Jan 7, 2001 01:26 PM
just file away one nibble on the 1156 bulb and it will fit. done on my 97se working fine and lights bright.
1HOTMAX Jan 7, 2001 01:47 PM
1156 works
i just did the thing benny said and it comes out nice....very sweet and the corners are brighter...one problem is it runs pretty hot but no problems yet...i ran it all day today and nothing yet. just clip off one with a nail clipper and sand down with sand paper. i just don't know if the amp for the fuse need to be redone....it's running on 5.5 i think
tgonza1057 Jan 7, 2001 01:53 PM
im not kidding
i used a flathead to hold the soket open while i put it in it works
WhteMax Jan 8, 2001 02:30 PM
Does it matter
which nibble u file down 2 get a brighter light??????
maximumsportZ Jan 8, 2001 02:35 PM
hmmm
well i just did this mod and it seems to hot very quick... think anything might happend?
benny Jan 8, 2001 07:22 PM
Re: hmmm
It should work just fine, the 1156 bulb is 27w. if you re-wire the 1157 bulb is 8w/27w, so you just wiring up the 27w filment, same wattage, what can go wrong?
maximumsportZ Jan 8, 2001 07:55 PM
benny
whats the best to make the side markers match the brightness now the corner bumper lense?
breaux124 Jan 9, 2001 08:00 AM
Filing off the nibble on the 1156 lights should work, but aren't the nibbles there to secure the lights into the housing? Doesn't the bulb have a chance of coming out of the housing then?
benny Jan 9, 2001 08:09 AM
you will still have 1 nibble to hold the bulb in. it is still secure.
1HOTMAX Jan 9, 2001 04:22 PM
everyone who is afraid, listen to benny!!!!
file one nibble off the 1156 and replace where the 1157 use to be. i've been running it for like 4 days and no problems except that it heats up hot. nothing is melted so i give it a 2 thumbs up
btw...benny, where u live at....you got good ideas...i live in flushing
xraydoc99 Jan 9, 2001 05:59 PM
Any helpful hints on getting the rubber piece out of the knob?
xraydoc99 Jan 9, 2001 06:00 PM
Sorry, above posted to wrong thread:)
benny Jan 9, 2001 06:44 PM
Re: everyone who is afraid, listen to benny!!!!
pretty close to you just over the george washington bridge.
1HOTMAX Jan 9, 2001 07:18 PM
benny
what type of bulb to match the headlight. i'm using nokya artic blue 9004 and hybrid 1156 but the headlight still whiter. hey what other mods are on ur ride? i got a 99, any other good ideas?
bigtexan7 Jan 9, 2001 10:43 PM
I tried Benny's little trick today and it worked great!
I just used my 1157s that were in there, turned the bulb around and filed off the nib and voila!
