Mileage and throttle response problems
I have a '97 5-speed with about 35k miles on it, mostly city miles. When the car was new, I would get a consistent 24-25 mpg. I can barely get 21 now and I am super-nice (2500 rpm upshifts, no a/c, etc). Also, the throttle response (still great compared to a FORD) has been much slower, almost stalled the car a few times due to this. Any idea what's going on here? Nothing has been replaced, just oil changes every 3750 miles.
- low fuel pressure
- bad Throttle Position Sensor
- "lazy" Oxygen Sensors
- sticking fuel injectors
- dirty Throttle Body
- anything which prevents the Engine Control Unit from
going into closed loop mode (e.g. thermostat stuck open,
bad Engine Coolant Temperature Sensor)
clean your throttle body
Before you try any costly or intensive repairs, buy some throttle body cleaner and clean it out really good. It worked for me. I just went on a 400 mile trip and got 28 or 29 miles a gallon. Much improved over what I usually get.
Re: Another q :)
Originally posted by OgreDave
How do you check/fix low fuel pressure?
Tryin to collect as much info as i can :>
96sleeper urged you to clean the Throttle Body before getting involved in more costly repair options. That's good advice. Along the same lines, you might replace your fuel filter as an early step. A partly clogged filter would reduce fuel pressure even if the pump is healthy. Inadequate fuel pressure results in a poor spray pattern at the injector tips. This might diminish the crisp throttle response you enjoyed when the car was new.
Re: Re: Re: Another q :)
How about changing the spark plugs? Could this be a major contributor to my poor gas mileage? Or should they been in fairly good shape after 35k miles?
Did you replace the air filter element as part of your 30K service?
Mine Did the same thing.
Mine is a '96 SE with 175,000 miles on it, so we are in a little different situation. My Problem was my clutch. From what you described it sounds exacctly like what I experienced. My final clue that it was the clutch was when accelerating hard in gear at any rpm the engin would run up a few hundred rpm then drop down and then the power came in. I took it in to the dealer and got it replaced for $730. Now my mileage is back up, and my clutch is so tight I look like a new 5-spd driver hopping around in first. This might not be your problem, but I thought some advice can't hurt. Good luck!
03-12-2020 12:06 AM
chernandez1278
09-16-2015 01:18 PM
97_GXE
09-15-2015 06:47 AM
