all those with automagic's
when driving around city streets do you have o/d on or off? i know this is a stupid question but i just wanted to know
Re: all those with automagic's
Originally posted by nesquiknate when driving around city streets do you have o/d on or off? i know this is a stupid question but i just wanted to know |
I drove with it off if I was in stop and go traffic.
If it was traffic that opened up a little bit and I could get above 30, I turned it on. |
:o)
Originally posted by clee130 I drove with it off if I was in stop and go traffic. If it was traffic that opened up a little bit and I could get above 30, I turned it on. Why? |
OD is always on since I have to go above 40mph all the time. unless im in stop and go then its off
Originally posted by clee130 I drove with it off if I was in stop and go traffic. If it was traffic that opened up a little bit and I could get above 30, I turned it on. |
Originally posted by 99maximagxe I drive in stop and go traffic all the time (Cali) I dont turn o/d off cuz i heard it consumes more gas so i leave it on. Do you feel any difference in terms of mileage? with o/d on and w/ it off |
Originally posted by DerekJ212 Of course it would take more gas. Its simple, look at your RPMs with it on, and watch them increase with it off. More RPMs, more gas... |
:o)
Originally posted by Nismo OD is always on since I have to go above 40mph all the time. unless im in stop and go then its off Why do you guys feel you need to turn it off when you are at low speeds? That makes no sense. |
Originally posted by nesquiknate when driving around city streets do you have o/d on or off? i know this is a stupid question but i just wanted to know i throw in to 2 and drive on ... tranny cooler kicks a$$ !! VB mod and traffic do not combine well ...with stop n go traffic |
Re: :o)
Originally posted by ptatohed Which is it? always or not? lol. Why do you guys feel you need to turn it off when you are at low speeds? That makes no sense. doing this in stop and go traffic may waste a bit more gas, but nothing significant unless going at higher speeds. the reason to turn off o/d is to stop the transmission for shifting back and forth between 3rd and 4th gear in stop and go traffic. this is better on the transmission (less shifting), and eats a bit more gas. |
Re: Re: :o)
Originally posted by Dev i drive stick but ill post anyways. doing this in stop and go traffic may waste a bit more gas, but nothing significant unless going at higher speeds. the reason to turn off o/d is to stop the transmission for shifting back and forth between 3rd and 4th gear in stop and go traffic. this is better on the transmission (less shifting), and eats a bit more gas. It's really a personally preference. Some people leave it on all the time, some people turn it on and off. The manufacturer put O/D there for a reason, might as well use it. |
Yes, sometimes when I'm in slow traffic I'll turn off o/d too. The car drives more smoothly since it doesn't shift gears as much.
overdrive merely tells the car whether or not it can go into 4th gear. The 3rd gear RPM's will be different as a result.
Mine is almost always on. If there is a lot of snow, sometimes I turn it off to make sure I stay in a certain RPM level. |
Mine is always on.
Originally posted by MarkD Mine is always on. Gotta love 'automagic'. |
I leave mine on, but when I'm in traffic I turn it off.
You know... I thought about it once, but didn't do it.
Re: :o)
Originally posted by ptatohed Which is it? always or not? lol. Why do you guys feel you need to turn it off when you are at low speeds? That makes no sense. |
Originally posted by clee130 I drove with it off if I was in stop and go traffic. If it was traffic that opened up a little bit and I could get above 30, I turned it on. LOL! :D :D :D Dumb moderator. |
My O/D is always on even w/ the high amounts of stop-n-go driving here in metro Detroit
gettin time for a tranny flush soon |
with OD on, the torque converter will "lock up"...meaning it will cease being a fluid coupling and become rigid. this will reduce the heat the torque converter has to deal with and increase your car's efficiency....but if its going in and out of lock up (like in stop and go traffic that gets over 35-40mph), that wears on it. Excessive heat is the biggest enemy of your transmission and torque converter.
I turn OD/OFF when I'm in city traffic. It keeps the tranny in 3rd gear which makes the car more responsive. I don't want to be in 4th gear @30 MPH trying to get in front of a cab.:mad:
There's also less shifting that the tranny has to do which I feel keeps wear-n-tare down. Less shifting the tranny has to do means the longer it's gonna live.:) |
Re: Re: all those with automagic's
Originally posted by GoldenGlory since i got my VB mod done @ jeff;s i throw in to 2 and drive on ... tranny cooler kicks a$$ !! VB mod and traffic do not combine well ...with stop n go traffic |
just leave it on
i switch mine off in stop n go traffic. my car shifts much less with it off below 30 mph. otherwise i leave it on...hope all of our replies are helping you decide what to do...
Re: Re: Re: all those with automagic's
Originally posted by NATE98GLE Why doesn't the VB mod and traffic combine well with stop n go traffic? |
We have an O/D button?
Just kiddin... just gives you an "extra" gear for highway traveling....High RPM's = harder on the engine |
thanks for all the replies on this. it made me decide to leave iton b/c i onl drive back and forth to school, which doesnt deal with much traffic
:D |
I turn OD on/off on the street and on the highway. Does it really make any difference? Maybe, maybe not. Since I have an automatic and not able to shift, I got nothing else to do so why not turn OD on/off. :D
| All times are GMT -7. The time now is 09:17 PM. |
