Don't Turn Corner Bulbs Around For Brighter Lights #2!!!!!!!
i rewired my corner lights for 2 months running 60 amps total in both fuse box (supposely 22.5 amps). my bulbs were APC superwhite and i followed the instruction by simply cuttin the lower nut to make it brighter.
the problem is if i dont' run 60 amps my fuse will keeps blowing and my t.tail lights won't come out. and it will also burn my circuits for running such a high amps. 2 days ago i picked up some raybrigs corners (japan imported), changed all fuses back to it's stock amp... and at night the corner light did not seem any dimmer than the one i rewired. i am very happy with the $31 raybrigs i payed. this is just my personal experience, any feedbacks are welcome. |
Re: Don't Turn Corner Bulbs Around For Brighter Lights #2!!!!!!!
Originally posted by happyricefob i rewired my corner lights for 2 months running 60 amps total in both fuse box (supposely 22.5 amps). my bulbs were APC superwhite and i followed the instruction by simply cuttin the lower nut to make it brighter. the problem is if i dont' run 60 amps my fuse will keeps blowing and my t.tail lights won't come out. and it will also burn my circuits for running such a high amps. 2 days ago i picked up some raybrigs corners (japan imported), changed all fuses back to it's stock amp... and at night the corner light did not seem any dimmer than the one i rewired. i am very happy with the $31 raybrigs i payed. this is just my personal experience, any feedbacks are welcome. I've had Polarg 1156 bulbs in my clearance lights for many months, never a problem . Yes, the 1156 bulb (single filament) will work, just cut a knub so it can fit in the socket. You're wasting your money... |
can you guys
Can someone Give me the web site were it showed you how to do this???
Re: Re: Don't Turn Corner Bulbs Around For Brighter Lights #2!!!!!!!
Originally posted by araffio You won't be happy when those $31 bulbs blow.. I've had Polarg 1156 bulbs in my clearance lights for many months, never a problem . Yes, the 1156 bulb (single filament) will work, just cut a knub so it can fit in the socket. You're wasting your money... |
http://www.danimsta.com/
click on how to. click on HOW TO--make the corners on your 95-99 maxima BRIGHTER I searched. where's the candy? |
lol if i had candy i would give u some :(
but o well i have had my brighter corners for awile and they are workin just fine! :) |
Originally posted by happyricefob i rewired my corner lights for 2 months running 60 amps total in both fuse box (supposely 22.5 amps). my bulbs were APC superwhite and i followed the instruction by simply cuttin the lower nut to make it brighter. the problem is if i dont' run 60 amps my fuse will keeps blowing and my t.tail lights won't come out. and it will also burn my circuits for running such a high amps. 2 days ago i picked up some raybrigs corners (japan imported), changed all fuses back to it's stock amp... and at night the corner light did not seem any dimmer than the one i rewired. i am very happy with the $31 raybrigs i payed. this is just my personal experience, any feedbacks are welcome. |
I've had my normal, non-hyerwhite autozone blubs turned around with a cut nub for almost 2 years now with no problems.
:sprint:
:sprint:
I never had a problem with my bulbs either and I installed them backwards corner front. I have $1.29 bulbs still shining bright and strong. |
I clipped my stockers...1 yr ago..no probs. They have a yellowish tinge to them, but thats ok for now.
ugh...this thread was from like 2 months ago, how did it get bumped?
anywayZ it doesn't matter anymore cuz i wrecked my front, i don't even have the corner lamp and don't even talk about brighting the corner bulbs... this accident is lookin for $3,000 full package. shiet i'm screwed. =( |
| All times are GMT -7. The time now is 10:39 AM. |
