Maxima Forums
Maxima Forums (https://maxima.org/forums/)
-   4th Generation Maxima (1995-1999) (https://maxima.org/forums/4th-generation-maxima-1995-1999-6/)
-   -   can't find screws to adjust headlights (https://maxima.org/forums/4th-generation-maxima-1995-1999/150336-cant-find-screws-adjust-headlights.html)
kev926 Apr 11, 2003 11:16 AM
does anyone know where the screws are to adjust the headlights? i couldn't find them. they're behind the headlights right? what do they look like? anyone by chance have a pic of what they look like?
THanks!
xHypex Apr 11, 2003 11:50 AM
I don't have any pictures, but they're metal rods with plastic end caps. You can use a wrench on them to adjust them.
-hype
Ravq Apr 11, 2003 08:25 PM
There's two adjustments per headlight. The one for aiming up/down is at the outer/lower corner of the headlight and the one for aiming right/left is on the inner/upper of the headlight (toward radiator).
kev926 Apr 11, 2003 10:14 PM
okay i'll check again. just that last time i looked i couldn't see anything. are they easy to spot?
ZuMBLe Apr 11, 2003 10:47 PM
Check the driver side first. The passenger side adjustments may be covered by a shield. Driver side is top of lamp towards the middle of the car.. and bottom of lamp towards the tire. Opposite for the passenger side.
kev926 Apr 11, 2003 11:56 PM
thanks!
A5295 Apr 12, 2003 08:24 AM
I just installed my new hl assembly on the driver's side. when adjusting headlights, how far do you need to be away from a wall to adjust them?
ZeRo MaX Apr 12, 2003 05:13 PM
it would be nice to have some pictures... hehe... i need to adjust mine too.. it seems too low... the light is not as far...
kev926 Apr 12, 2003 06:18 PM
I found it. if you look closer it's not that hard to find. It sticks out a lot, is a metal bar with a black plastic cap on it that has six sides. you can use a wrench to adjust it.
the question i have is though... i tried turning it today and i turned it a little bit but didn't see any changes. Do you ahve to turn it a lot to see a change in the light direction? i'm trying to be careful so i don't screw it up and not be able to go back to what it was originally...
from what i remember, on the height one, counterclockwise is adjusting the light to point down, right?
