Maxima Forums
Maxima Forums (https://maxima.org/forums/)
-   4th Generation Maxima (1995-1999) (https://maxima.org/forums/4th-generation-maxima-1995-1999-6/)
-   -   rpm's rev when i give gas on 5 spd with no clutch depression (https://maxima.org/forums/4th-generation-maxima-1995-1999/157608-rpms-rev-when-i-give-gas-5-spd-no-clutch-depression.html)
shane12286 May 15, 2003 06:59 PM
recently my 96 5 speed revs when i push the gas in a gear when the clutch is not depressed and the rpm's rev up and not alot of acceleration then they go down again and i accelerate. this is due to an worn out clutch correct? just want to make sure.
Miasma May 15, 2003 07:36 PM
you need a new clutch.
Craig Mack May 15, 2003 07:57 PM
my old dynomaxx clutch did it. 99% sure it's your clutch. how many miles on your car? Original clutch? What is your driving style?
shane12286 May 15, 2003 08:30 PM
135000 miles i dont know if its the orginal becuase i just bought the car at 130000 and i have been driving it pretty hard
96BLUMAX May 15, 2003 08:38 PM
Yeah its the clutch.
Dev May 15, 2003 10:03 PM
clutch is definitely dying
better get if fixed ASAP, before the flywheel gets damaged.
ChristheNite May 15, 2003 10:15 PM
Yeah, I had the SAME problem - its the clutch. And unfortunatly it cost an arm and a leg for a new Nissan Clutch. Dont worry about the flywheel, they will have it resurfaced - consider an aftermarket clutch...Nissan will KILL you on the price... just my .02$
